I've done a lot of searching on the TDB but can't find an answer to what harmonic balancer I have. It is stamped on the face with 7173, so I assume it is part number 381173. And a date code of G0F. I think that is July 70, not sure what the F is, maybe shift code.
I attached a picture of a 381173 (non-finned) painted orange that I found on the TDB. Note that the "spokes" on the face radiate out to the outer ring. The other picture is of the one I just purchased and the "spokes" are different.
As a side note, The one I have matches the one in Colvin's book that he says is the Fifth Design of the small block SHP balancer.
I'm sort of thinking I may have a balancer from a 350 instead of a 327 SHP. It is 8" diameter and 1 11/16" thick.
I plan to use it on a L79 engine build. Not a numbers matching build, so I'm not concerned with judging. Any problem using it for that?
Don Harris
Don Harris
