Best source for original bumper bolts? - NCRS Discussion Boards
  • Ed S.
    • August 6, 2014
    • 1388
    Re: Whereabouts of Rich Pasqualone?
    Font size of the "M" on repros is not the same as an OEM "M".
    Ed
    • Gary B.
      • February 1, 1997
      • 7067
      Ed,
      And there's a difference in the length of the middle downward V segment of the M.
      Gary
      • Leif A.
        • August 31, 1997
        • 3652
        #18
        Richard Fortier should be able to fill your order, as well.
        Leif
        • Frank D.
          • December 27, 2007
          • 2703
          #19
          My 63 had some "M" bolts on it but mostly "TR"s....and yes the font is definitely thinner and less defined on the repros:
          • Mike B.
            • July 31, 1994
            • 843
            #20
            Re: Best source for original bumper bolts?
            Hi Gary,
            It's not often that I'm thoroughly satisfied with an order from a parts vendor. But just recently I ordered 2 air conditioning parts for my '66 from David Sokolowski. A compressor bracket and an interior duct. Both were fine examples. No issues. This was my 3rd order with him.
            For many years I'd been searching for a matching "3 Dot" head mark evaporator screw that was missing from my '66 evaporator box when I bought it in '88. I knew in the past that David wasn't selling his bolts/screws. He is now. I sent him an e-mail with detailed photos of one of my originals and BINGO, he had them! Exact match! I bought a complete set of four since he offered them up. A BEAR to find! I'd also included some shots of the two AC STV bracket screws that I needed. Voila! He had exactly what I wanted.
            My '65 had a mixture of mostly "M" and "TR" shorter bumper bolts all around. Longer "RBW" bolts in the rear. Those black grade 8 "WB" long bolts up front. My '66 rear bumper bolts were short "TR". Longer bolts were "RBW" side by side on the edge of the bolt. The '66 front bumpers & brackets were missing in '88.
            Let us all know what you come up with on that '64. What head marks you chose?
            Mike
            • Enzo C.
              • January 12, 2012
              • 536
              #21
              Rich is around... sometimes he just takes a while to reply
              Enzo Colosimo
              Ncrs Ontario Chapter Chairman 🇨🇦
              ENZ-Z06/67
              • Rich P.
                • January 12, 2009
                • 1361
                #22
                For 64 the best choice would be WB.20190329_171129-1008x567.jpg20190329_171129-1008x567.jpg
                • Gary B.
                  • February 1, 1997
                  • 7067
                  #23
                  Welcome back, Rich.
                  Gary
                  • Richard G.
                    • July 31, 1984
                    • 1718
                    #24
                    Below is a picture of a bumper bolt I removed from my 1963.
                    Below is a reproduction bumper bolt as sold by Paragon.
                    • Rich P.
                      • January 12, 2009
                      • 1361
                      #25
                      Thanks Gary!
                      • Gary B.
                        • February 1, 1997
                        • 7067
                        #26
                        Rich,
                        M's were a common headmark for some C2 years, but Paragon does not want to make a bumper bolt kit that is different for each C2 year. So it's one size fits all as far as Paragon is concerned. Also, the Paragon M does not look like the original M, which has a longer central leg that goes down to the font baseline.
                        Another problem exits for the lock washers Paragon sells with their C2 bumper kit, Three different sizes/finishes of bumper lock washers were used between '63 and '67, beginning with standard size in zinc, then changing to standard size, but unplated, then changing to thicker ("hi-collar"), unplated. But again, Paragon sells a one size fits all bumper hardware kit.
                        Gary
