57 banjo bolt torque spec - NCRS Discussion Boards
  • Ed P.
    • July 31, 2002
    • 270
    Is there a torque spec for the brake master cylinder banjo bolt ?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11364
    Re: 57 banjo bolt torque spec
    Ed, Good question.
    I checked the AIM and ST-12. No torque spec in either one.
    ST-12 simply states to "tighten" it. I usually give it a good strong tightening and hope it doesn't leak. If it does, I tighten more.
    New copper washers are best, or as some have suggested, anneal the old(cleaned) washers with heat.
    Rich
    • Gary C.
      Administrator
      • October 1, 1982
      • 17940
      have found that using the aircraft EZTurn sealer with new washers work great to seal a C1 master cylinder. I use this on all brake & fuel line connections. https://www.aircraftspruce.com/catal...ezturnlube.php Available from a local aircraft supply house.
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Jim L.
        • September 30, 1979
        • 1817
        I have a tri-five Chevy with a master cylinder which has a banjo bolt. To the best of my memory, the torque spec for it is 65 ft-lbs. Assuming my memory isn't defective, I'd expect the torque for the Corvette master cylinder to be similar.
        Jim
        • Ed P.
          • July 31, 2002
          • 270
          I found a chart online that says 1/2 inch banjo is 75 foot lbs.
