350 Ram Jet Engine
Re: 350 Ram Jet Engine
Gerald------
You could use the 14" flywheel if you also use an 11" clutch and a bellhousing designed for use with a 14" flywheel (e.g. GM #3899621).
Otherwise, you can switch to an externally balanced 12-3/4" flywheel. The standard weight version is GM #14088650.
By the way, all Gen I small blocks equipped with a 1 piece seal type crankshaft such as your RamJet 350 use an externally balanced flywheel or flexplate.In Appreciation of John Hinckley- Top
A bit off topic, but does the plenum on a Ram Jet motor fit under a stock small block hood?Mike
1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.- Top
- Top
Fits fine in my friends 63 SWC.
Mike T - Prescott AZAttached FilesMike T. - Prescott AZ.- Top
