chrome bumpers - NCRS Discussion Boards
chrome bumpers
  • Mel S.
    • August 31, 1992
    • 264
    chrome bumpers
    Can anyone recommend where to get my 66 bumpers re-chromed or is it more cost effective to buy USA ones from Corvette Central?
    Mel
    • 6960
    Re: chrome bumpers
    Mel factory original bumpers are the better choice to have redone.
    • Leif A.
      • August 31, 1997
      • 3654
      Re: chrome bumpers
      Mel
      Paul's Chrome or Librandi's Plating...both in Pennsylvania.
      Leif
      • Mel S.
        • August 31, 1992
        • 264
        Re: chrome bumpers
        Ok and thanks
        • John D.
          • December 1, 1979
          • 5507
          Re: chrome bumpers
          Mel, I highly recommend M&P Refinishing of Jeannette, PA. Family run business for ever. The Kerin Brothers. I use them all the time.
          They have a website.
          212 South 5th St. (across from the post office), Jeannette, PA. 15644
          724-527-6360 Winter hours. Open 8 to 5 EST Mon thru Thurs. Fast turnaround. They do die cast also. John
          • Dick W.
            • 10483
            Re: chrome bumpers
            Advanced Plating in TN. Best out there since the demise of Lemon Grove Plating
            Dick Whittington
            • Jack J.
              • July 31, 2000
              • 640
              Re: chrome bumpers
              Gentlemen, I just checked out Corvette Central's 63-67 USA made front and rear bumpers (4 pieces ) and their price is $2319.00 plus tax. Would someone share their actual costs, disregarding any repair work, to have their bumpers replated by those mentioned above or others not mentioned. Also, explain how the old chrome was removed that is, chemically, reverse polarity, or by manually grinding. I know the reproductions are "thinner" but "NEW", verses replated originals, pitted on the backside. Thanks, Jack J.
              • Keith B.
                • September 15, 2014
                • 1604
                • Jim D.
                  • 2885
                  Re: chrome bumpers
                  The chrome plater I've been using for decades charges $250 a corner. As far as replacement bumpers go, Paragon has the original GM tooling and their bumpers are identical to the originals. If they don't fit your car correctly, it's because of incorrect prior repairs. My current project, a 1965, had the typical 70's mod of removing the front bumpers. I purchased all the brackets and new bumpers from Paragon and the fit was perfect. I had the rears re-chromed and you can't tell the difference between them. Same finish, same thickness etc.
                  • Michael B.
                    • February 1, 1985
                    • 76
                    Re: chrome bumpers
                    Who do you use for your chrome, Keith?
                    • James G.
                      • August 22, 2018
                      • 816
                      Re: chrome bumpers
                      I found someone who provides a finish much closer to what the factory used,
                      They will also leave halos by installing a bolt like the front C3 bumpers were plated etc.
                      I call it "production chrome" as a way to distinguish it from triple or Show chrome.
                      R& D Plating in Tri cities Tenn.
                      They will note the sanding scratches and heavy tooling marks and replicate,
                      they electrically strip the part,
                      Prep the surface etch,
                      do a nickel strike then replicate the sanding scratches,
                      2nd nickel strike -
                      polish -
                      Clean
                      Chrome strike.
                      Here is a rear bumper they did for very correct 2nd gen Z28 which used some NOS Chrome along with some replated original parts -
                      The fine sanding scratches are present in the chrome of every survivor I have ever inspected.
                      The bumper had heavy grind marks like this
                      Crisp edges, not over polished with nice not over polished profiles.
                      James A Groome
                      1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
                      1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
                      My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
                      Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
                      • Alan D.
                        • January 1, 2005
                        • 2054
                        Re: chrome bumpers
                        Well perhaps the C3 and 2nd gen Z28 were produced at a much lower standard (& yes things were going down hill in later years), but C2 were much better.
                        I have an original (came on my 64) which shows excellent quality on top sides, no scratches, no grind marks, no sand marks.
                        The underside does show distortion where the supports were welded, and some light sanding marks/distortion were pieces were welded for corner.
                        Purchased a few hundred bumpers in early 70's for friends (getting deep discount) and for the most part they always showed sanding marks, distortion, scratches, - ie junk stuff, returned on a regular basis just to get acceptable ones for drivers
                        The NOS p are out there in large numbers so perhaps these are mostly seen.
                        Agree with Gene below, he said better
                        • Gene M.
                          • April 1, 1985
                          • 4233
                          Re: chrome bumpers
                          The Corvette was GM’s flagship car they didn’t want any crap going out the door. Chrome on them for the most part was very good. Corvette and Cadillac were the pride of the fleet. And the line supplied parts were far superior to the parts sent for service replacements. NOS is not an indicator of assembly line pieces in quality. There may have been lesser attention paid to the part quality on other assembly lines in GM. But those lower quality assembly line parts were rejected on the Corvette line.
                          • Ronald L.
                            • October 18, 2009
                            • 3248
                            Re: chrome bumpers
                            Jim, last I heard the tools needed a full refurbish costing over 250k, and were sitting - have you checked with them?
                            • Brandon T.
                              • October 23, 2008
                              • 872
                              Re: chrome bumpers
                              what is the name of the place that does your chrome work?
