1966 L36 Fuel Pump AC 6440366 - NCRS Discussion Boards
  • Peter M.
    • February 1, 1984
    • 361
    Page 114 of the 5th addition 66 TIMJG calls out the correct pump as part # 6440366 - yet the picture (M-35) on the same page showing an example shows IH40366! I have an original pump that has part#40366 that matches the description on page 114 of the casting and other attributes - except does not have the 64 in front of 40366. I'm confused! Is 40366 a correct late 65 / early 66 L36 fuel pump?
  • Larry M.
    • January 1, 1992
    • 2701
    Re: 1966 L36 Fuel Pump AC 6440366
    Peter:
    For fuel pump identification/stamping not all the part number digits are used. 40366 is fine.
    Now be advised that the letters associated with the fuel pump numbers are actually date codes. I do not think our judging has progressed to the point that most judges know how to evaluate them. But this has been discussed in this forum before, and the information is in the archives. David L. is one source of this information. You might search under "fuel pump date codes" or something similar to find these threads.
    Larry
    EDIT: Here is one link to get you started: https://www.forums.ncrs.org/showthre...ump+date+codes
    • Peter M.
      • February 1, 1984
      • 361
      Thank you Larry - very helpful and appreciated.
      Originally posted by Larry Mulder (20401)
      Peter:
      Larry
      • David L.
        • July 31, 1980
        • 3310
        IMO the "IH40366" pump would be dated Sept. 1968.
        Dave
        • Peter M.
          • February 1, 1984
          • 361
          Thanks David - the IH I mentioned was from the picture in the 5th addition NCRS TIJMG - My pump has the 40366 but no letters
          • David L.
            • July 31, 1980
            • 3310
            I would say your 40366 pump is original assuming it has the "AC" casting.
            Dave
              • 43247
              Dave
              Dave and Peter------
              Well, if it's original, it's a "ticking time bomb" at this point.
              AC fuel pumps and other AC parts usually followed a strange practice of using different part numbers for PRODUCTION and SERVICE for the same part. For the 1966 big block fuel pump the PRODUCTION part number was GM #6440366. The SERVICE part number for the same fuel pump was GM #6416245 which was discontinued without supersession in 1980. However, the AC type number and the number used if you bought the SERVICE pump from an AC dealer was always the last 5 digits of the PRODUCTION part number or, in this case, 40366. That number was found embossed on the pumps whether PRODUCTION or SERVICE pumps. The only reason I've ever come up with for the difference between the PRODUCTION and SERVICE GM part numbers is that the SERVICE pump was supplied with a gasket while the PRODUCTION pump was not.
              By the way, I think there was a modest change in the configuration of the 40366 fuel pump during the years of its manufacture but I've forgotten what it was. Possibly something having to do with the configuration of the inlet or outlet fittings.
              • Julio G.
                • March 28, 2017
                • 53
                As a side note as I am restoring a 66 L36, does anyone happen to have one of these fuel pumps laying around, new or used that they would be willing to part with?
                Thank you,
                JJ
