REAL 57 283 HP FI heads - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8409
    has anyone observed an embossed X on the exhaust manifold face of 539 heads? I've got six 539's cast dated between mid may and late July of 57, and all six heads have the embossed X. btw, the X would be inspectable on the judging field and if all 283 hp heads have this X, it may identify heads on a 283HP judged car that is sporting a pair of pass car heads(which aren't cast #'d 539 ) and I doubt have the embossed X. Mike
  • Peter M.
    • May 30, 2013
    • 361
    Re: REAL 57 283 HP FI heads
    Mike,
    About 45 years ago a friend of mine used a pair of those heads for fill when he got his driveway paved. As far as I know they are still there.
    The deed was done before I found out.
    Kind regards.
    • Mark S.
      • July 31, 1983
      • 666
      A set that I had years ago had the "X" on them. When I sold them, I missed the previous high prices in the market!
      • Dan P.
        • December 1, 1990
        • 683
        I have a lot of the 539 heads with and without the X . The earlier heads did not have the X .But every late 539 that I have had them and I believe the 58 770 head had them also.
        • David G.
          • May 31, 1980
          • 275
          Mike
          Can you post a photo of the X on the heads.
          Dave
          • Todd H.
            • 120
            The 539 heads on my original engine '57 FI, which I have every reason to believe are also original (cast in early '57) have no X that I can see.
            That picture would help.
            • Wayne L.
              • September 30, 1981
              • 233
              I have a 539 head cast C-4-7, and it has no "X". I have seen later 539's with the "X".
              1958 770 and 772 heads are cast with "X58" in the area Mike talked about-visible between the exhaust manifold and the head.
              I have a 550 cast in April 59 with an "X". This "X" cannot be seen with the valve cover on as it is in between the openings for the pushrods.
              • Joseph T.
                • April 30, 1976
                • 2074
                Early 539 K and B no X
                • Jimmy G.
                  • November 1, 1979
                  • 977
                  I have been told that the first production run of earlier heads had an "X" after that it was supposedly dropped. I found that to appear to be correct on 1958 770 heads
                  • Mike M.
                    • May 31, 1974
                    • 8409
                    Originally posted by David Gray (3627)
                    Mike
                    Dave
                    I'm mentally challenged when it comes to posting photos, here and elsewhere but I can send a photo to vinny Peters who, in the past, has posted them here for me. mike
                    • Perry M.
                      • January 1, 1977
                      • 325
                      It's hard to tell from the pictures but I don't think those are 539 heads. The casting symbol at the end of the heads appear to be a low horse power version or perhaps 997 heads especially since your motor has a dual 4 barrel manifold on it. A picture of the end of the head or casting number would confirm.
                      • Vinnie P.
                        Editor NCRS Restorer Magazine
                        • May 31, 1990
                        • 1583
                        Here are the photos Mike sent me, painted pair cast in May and rusty pair in early June
                        • Mike M.
                          • May 31, 1974
                          • 8409
                          Mike
                          Dave
                          Dave: the photos were sent to vinny. i had to unwrap the heads from their tightsy-whitesies prior to photo-ing them. the bev manager.
                          • Joseph T.
                            • April 30, 1976
                            • 2074
                            • Joseph T.
                              • April 30, 1976
                              • 2074
                              Ignore the manifold. Heads are just bolted to a spare block. These are early 539 heads. Passenger car maybe!
