Holley 4160 numbers - NCRS Discussion Boards
Holley 4160 numbers
  • Donald O.
    • May 31, 1990
    • 1593
    Holley 4160 numbers
    I know it is not original for a 67 Vette 327-350hp, but what is it from/for?
    Air Horn
    3875984-DB
    LIST-3320
    3224
    Rear Bowl
    ink stamped
    3261D
    Metering Plate
    4781
    3230
    Don
    • 43293
    Re: Holley 4160 numbers
    Air Horn
    3875984-DB
    LIST-3320
    3224
    Rear Bowl
    ink stamped
    3261D
    Metering Plate
    4781
    3230
    Don
    Don------
    I think you might have the numbers wrong here. Might the GM part # be 3875964 and the list 3230? If so, it's a Holley model 4160 from a 275 horsepower 327 originally installed in a passenger car. I can't find any Holley carb with the numbers you mention. We know it has to be for a GM application because it has a GM part number. However, if it is actually the numbers you provided, it could be for a non-Chevrolet GM application.
    • Donald O.
      • May 31, 1990
      • 1593
      Don------
      Joe
      You are correct, as usual, the correct list number is LIST-3230.
      Don
