1966 Shifter Installation - NCRS Discussion Boards
  • Walter R.
    • January 6, 2009
    • 271
    I replaced flywheel and took shifter out in process. The shifter came out from behind crossmember with transmission still installed but released from bellhousing. I have re-installed transmission and am having a difficult time installing shifter. Could I get some guidance on installing shifter with transmission in place?
    • 6942
    Re: 1966 Shifter Installation
    Walter do you have the driver side front pipe installed?
    • Walter R.
      • January 6, 2009
      • 271
      Sorry, I should have stated in first post that car has sidepipes
        • 6942
        Walter, I done a quite a few mid year transmissions and clutches,I generally work from either front or rear of the cross member. the mount is also installed as that transmission sits a little higher.
        • Walter R.
          • January 6, 2009
          • 271
          You can install shifter with mounting bracket attached.
          • Don H.
            • December 1, 1981
            • 1487
            I have loosened front engine mounts and the transmission mounts and literally pushed the engine / transmission over to the side to get a little more room on a 1960 (you don't get much but every little bit helps). I'm not sure if you could do this on a mid-year. Don H.
            • Robert C.
              • September 25, 2007
              • 6
              After loosening the motor mounts and trans mount, I used a ratching style tie down strap to keep the assembly to the side while installing the shifter
              • Robert C.
                • 6
                • Walter R.
                  • January 6, 2009
                  • 271
                  Shifter in. I had engine attached to chain fall to hold in place while I removed transmission. I pulled engine up as far as it would go, without removing engine mounts which raised transmission in tunnel. This gave ample room to install shifter from front of crossmember.
