C-3 weatherstrip - NCRS Discussion Boards
C-3 weatherstrip
  • Gary D.
    Infrequent User
    • August 31, 2002
    • 17
    C-3 weatherstrip
    Wondering who would have the best fitting and correct weatherstrip kit for a 1968 convertable ??
    • 11698
    Re: C-3 weatherstrip
    The short answer is that none of them are perfect.
    AFAIK only 2 companies make weatherstrip, Metro Moulded or Corvette Rubber. Catalog dealers sell one or the other or occasionally both.
    I think that Corvette Rubber "may" be a bit more correct. MM tends to be softer and thicker than original.
    However, neither company has the exact correct fit and material, in my experience, for an early C3.
    • Gary D.
      Infrequent User
      • August 31, 2002
      • 17
      ok thanks Patrick !
        • 43289
        Gary------
        Dr. Rebuild has identified the best and most correct manufacturer for each piece of weatherstrip and sells those. So, if you get them from him, the work of determining the best manufacturer for each piece has already been done.
        • Gary D.
          Infrequent User
          • August 31, 2002
          • 17
          OK Thanks .. I did order from Corvette Rubber Retail .. They sell for Missaukee Molded Rubber who supplies most of the vendors maybe even Dr Rebuild ... I'll call them tomorrow and find .. Thanks for your reply ,,,
            • 11698
            I believe that Corvette Rubber and Missaukee Molded are the same company.
            • James G.
              • August 22, 2018
              • 819
              Is it still best to search out and find NOS Latex covered foam weatherstripping?
              James A Groome
              1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
              1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
              My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
              Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
                • 11698
                Realize that it will be old weatherstripping, even if in the box. Not that what is on our cars isn't old, but you may find it brittle.
