I feel kinda dirty asking, but here goes... - NCRS Discussion Boards
  • Don L.
    • August 31, 2005
    • 1005
    Re: I feel kinda dirty asking, but here goes...
    Don-----
    All I need is the part number of the crate engine assembly. Otherwise, a photo of the crankshaft flange will do.
    Joe, I got the engine home today and uncrated it. I have attached a photo of the rear seal and seal housing. Does this photo allow you to provide me some guidance on which ARP flex plate bolts I need?
    If it matters, the flex plate is a Pioneer (part number FRA-159)
    Thank you!
    Don Lowe
    NCRS #44382
    Carolinas Chapter
      • 43221
      Thank you!
      Don------
      This engine has a 1 piece seal type crankshaft. The flexplate you have has the correct bolt pattern for this crankshaft. It is a 168 tooth flexplate and externally balanced (all 1 piece seal small blocks are externally balanced).
      You will need the ARP bolts of 0.725" length (ARP 200-2906) or 6 GM #3727207. For this I much prefer the ARP bolts.
      • Don L.
        • August 31, 2005
        • 1005
        #18
        A big thanks to all for contribution and advice! Much appreciated. A special thanks to Joe Lucia for his guidance. Joe, how does so much knowledge fit in your head? You're amazing!
        I'll order the ARP bolts tomorrow and begin assembly.
        A side note: when I un-crated the new engine yesterday, I read the dyno sheet that came with it. This GM 350ci block (over-bored to 357ci), coupled with Weiand aluminum intake manifold, Pro-filer aluminum heads (w/2.02-1.60 valves), Holley 680cfm carb, generates 397hp @ 5200 RPM. It makes 434 ft lbs of torque @ 4500RPM. Can't wait to have me some fun in this little truck...
        Don Lowe
        NCRS #44382
        Carolinas Chapter
