1965 fuel injection body identification - NCRS Discussion Boards
  • Joe T.
    • February 25, 2018
    • 153
    Going to look at a 1965 with fuel injection emblems. Looking up the vin and motor numbers given to me, I have been able to identify the motor is not original to the car. The current motor in the car is a L76 with HH on the pad (365HP). Is there any easy way to identify the body as an original fuel injected car?
  • Dan H.
    • July 31, 1977
    • 1368
    Re: 1965 fuel injection body identification
    See if the inside fenders show if the car ever had V flags mounted. They were not used on FI cars so if filled in equals carb car, not FI.
    1964 Red FI Coupe, DUNTOV '09
    • Bob I.
      • May 11, 2017
      • 34
      A good indicator is the fender bonding strip area. Look from under the hood both sides at the fender and top skin and see if there are flag holes above the F I emblems. Also check to see if the top skin has been replaced, the color on the bare fiberglass will differ if changed.
      • Joe T.
        • February 25, 2018
        • 153
        Thanks for the emblem installation identification. I will also check for welded lower radiator rod supports.
