Daily Job Number - NCRS Discussion Boards
Daily Job Number
  • Patrick C.
    • January 16, 2013
    • 327
    Daily Job Number
    I noticed 307 written on the inside of my door with what looks like a P ahead of it. Was this the daily job number? Did this mean my car was the 307 car built on January 25, 1964? Any idea what the P stands for?
  • Tom D.
    • September 30, 1981
    • 2143
    Re: Daily Job Number
    I have seen "X" after the job number on 1965 396 cars. I have not seen a "P", but never had a '64.
    Which co. made the body?
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Ray G.
      • May 31, 1986
      • 1189
      Hello
      Looks Like an "R" for right side ?
      What is the last three digits of your VIN ?
      I hope you dance
      • Patrick C.
        • January 16, 2013
        • 327
        St. Louis body, late Jan 1964 build date.
        • Patrick C.
          • January 16, 2013
          • 327
          Originally posted by Ray Geiger (9992)
          Hello
          9769 built Jan 25, 1964
          I looked at the picture again and it maybe a B? Likely an R....I will check the Drivers door for a L.
          • Patrick C.
            • January 16, 2013
            • 327
            No Joy! Drivers door has no number and but it also has an R
            • Blair K.
              • September 27, 2012
              • 170
              I can see a "307" on your left door also.
              • Patrick C.
                • January 16, 2013
                • 327
                Blair
                You have great eyes! I totally missed it, but now see it below the window crank.
                So I am guessing it was some type of daily job number but not sure about the R?
                My ‘66 has a similar number on the fiberglass under the gas tank
                • Frank D.
                  • December 27, 2007
                  • 2703
                  My 63 has the "334" number on both doors and the splash pan...no other digits/letters....it is my understanding that the daily job numbers went up to 500 each day....
                  • Jim D.
                    • 2885
                    The "307" is a typical job number for a St. Louis built body. No such thing as a "daily" job number. St. Louis used 1-500 and then started over again using the same sequence. A.O.Smith built body's used a letter prefix starting with "A" 1-500, then "B" 1-500 etc.
                    My SL car:
                    My A.O.Smith car:
                    • Michael J.
                      • January 27, 2009
                      • 7166
                      You might also look on the passenger side outer footwell, my '64s also have the body number (364 in this one) there.
