69 Radiator Baffle has me baffled - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1424
    Guys,
    trying to to figure out the placement of the various radiator seals and looks like I'm missing the radiator baffle that is pictured in the AIM and the vendors pic. Is this universally present in 69? Anyone know if this is available repop or do I need to source a used one? If I do have to install it it looks like it maybe bolts under the sway bar clamps? That seems strange to me. Can you guys set me straight?
    Mike
  • John C.
    • January 1, 2005
    • 616
    Re: 69 Radiator Baffle has me baffled
    Michael
    The baffle was only used on cars that had a steel fan shroud.
    John
      • 43289
      Originally posted by Michael Leonard (46610)
      Guys,
      Mike
      Michael------
      My original owner 1969 with 300 HP and 4 speed had the circular steel fan shroud and lower baffle.
      • Dennis D.
        • March 1, 2000
        • 1071
        Both those diagrams aren't showing the brackets tha attach to the 2 tabs extending below the steel shroud. Those brackets connect the shroud to front crossmember. Try to post pics.
