1957 t-10 - NCRS Discussion Boards
1957 t-10
  • Danny K.
    Infrequent User
    • September 30, 1992
    • 2
    1957 t-10
    does anyone have info on transmission bld.date corallations to car build dates for 1957 4 speeds.1957 4speed
  • Mike M.
    • May 31, 1974
    • 8400
    Re: 1957 t-10
    the corvette usually has to be built post-mid may of 57. the t-10 tail housing cast date ought to be a week to a month pre-build of the car. the date stamped on the cast iron case ought to be shortly after the cast date on the tailstock. anything else needed? mike
    • Danny K.
      Infrequent User
      • 2
      Re: 1957 t-10
      mike, thanks that seams to be the general therory. know of any vin surveys? I have trans main case casting 4/29 tail 5/20 build date stamp 10/24 to make it worse I have vin 4746 build date around 6/20/57
      • Dan P.
        • December 1, 1990
        • 683
        Re: 1957 t-10
        Many of the T10 had cast dates just like yours and not assembled till December 57 . Making them 1958's .Jerry Bramlet has a t10 with a earlier assembled date .It is listed on the Corvette Forum. You could always buy his and sell yours .
        • James G.
          • May 31, 1976
          • 1556
          Re: 1957 t-10
          I agree with all. Jerry has a nice trans.
          • Patrick S.
            • January 1, 1988
            • 209
            Re: 1957 t-10
            The T-10 information on my original transmission is: main case cast date =4-26, assembly date = WF1972 (June 19, second shift), tail shaft casting date is 4-27-57. The trans was original to VIN 5813.
            • Frank C.
              • March 1, 1977
              • 70
              Re: 1957 t-10
              My VIN is 4906 built June 30. I've had it since 1973. Original trans main cast date:3-20. Assembly date WF 1372. but my tail shaft must have been changed. It reads 5-20-60. See pix. Can anyone tell me what the tail shaft goes to?
              • Gary C.
                Administrator
                • October 1, 1982
                • 17771
                Re: 1957 t-10
                Frank,
                Trailshaft probably Corvette. Side cover doesn't appear correct for early '57 T-10 either. Remove the cover and the number should be cast inside.
                Please post a better photo of the Main Case as can't seem much past the fill plug. Thanks,
                Gary
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • Frank C.
                  • March 1, 1977
                  • 70
                  Re: 1957 t-10
                  Thanks for the reply. My original color was Arctic blue metalic and if the painter ever finishes it will be again. Here's a broader pic. The inside of the side cover will have to wait. What will I be looking for? Something like the stamping on the left rear? I'll check it out soon.
                  • Loren L.
                    • April 30, 1976
                    • 4104
                    Re: 1957 t-10
                    I "believe" there was a running change in the tailshaft mounting bolts from the initial 3/8" to 7/16", which may explain a # of mismatched extension housing dates......under warranty, of course. Can anyone verify?
                    • Bob I.
                      • May 11, 2017
                      • 34
                      Re: 1957 t-10
                      Here is a Jan T-10
                      • Frank C.
                        • March 1, 1977
                        • 70
                        Re: 1957 t-10
                        Originally posted by Gary Chesnut (5895)
                        Frank,
                        Gary
                        Gary, here's a picture of the inside of the side cover of my '57 4 speed. It reads T10-1480 with a 9 over the hyphen. To the left is embossed J1. Any help with confirming the correctness of the side cover or identifying it would be appreciated. Thanks
                        • Dan P.
                          • December 1, 1990
                          • 683
                          Re: 1957 t-10
                          The side cover should be aluminum and no reinforcement ribs around the bosses for the shift arms . The tail housing rear motor mount bolts were always 3/8. The tail housing changed mid 59 with the addition of a 2nd rear motor mount .
                          • Mike M.
                            • May 31, 1974
                            • 8400
                            Re: 1957 t-10
                            All three of the 57 T-10s I own or owned had tailhousings drilled and tapped for 3/8 coarse bolts. All 3 had gusset-less side covers .all had provisions for a single attachment point for floor shifter. All had tailhousings with crescent shaped machining where seal pressed into tail . All mike
                            • David B.
                              • March 1, 1980
                              • 689
                              Re: 1957 t-10
                              As a point of reference the '57 T-10 4 speed was drawn up by Chev. Engineering beginning 6-24-56 and finished 7-31-56. Along the way there were a TON of engineering changes made to improve, so there are a lot of variables in the early years. Mike's description pretty well sums up what the production version looks like. The Volume 13 #1 Restorer article by Wayne O. Loren was well researched and gives a pretty good description of the Warner T-10. Proto type versions such as O-147672 reported in the Nassau Corvette has it's own story along with the early '57 versions used at '57 Sebring. A small booklet could be written about it's development and the many changes it under went. Too much stuff to post etc. etc..
