57 Hood Latch Cable Firewall Mount - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    Both my 1957's came in boxes and I want to put this mount for the hood latch cable on the firewall. The AIM figure is not all I need. Does the black clip go on the passenger compartment or engine compartment side of the firewall? I assume that the raised part goes away from the firewall.
    I have a metal plate riveted to the firewall and one hole looks to fit the cable, but the other one is too small for the clutch screw unless i use a tap, in which case I wouldn't need the nut.
    Any help would be appreciated!
    Bob
  • Mark S.
    • July 31, 1983
    • 664
    Re: 57 Hood Latch Cable Firewall Mount
    I believe that the black clip would go on the firewall side. I also believe that two black clips go together to hold the cable.
    • Todd H.
      • 120
      Bob, if no one else responds I'll go out and get a picture of mine later this morning. -31 here right now.
      • Bob B.
        • March 1, 2003
        • 831
        Todd,
        Pics would be super. Mark says two on the outside, so i would guess that they attach back to back? The AIM shows the screw coming from the firewall side, but I always like to confirm the AIM.
        Sounds like you must be in the upper midwest!
        Bob
        • Todd H.
          • 120
          • Todd H.
            • 120
            • Bob B.
              • March 1, 2003
              • 831
              Todd,
              Thanks for the pics! I am heading out to the shop to put them on now!
              Bob
