C2 340HP Engine Gaskets - NCRS Discussion Boards
  • Richard S.
    • April 1, 2003
    • 288
    Looking for a good source for engine gaskets and material type for my 63 340 HP car. Suggestions appreciated.
    Rich
    • 43279
    Re: C2 340HP Engine Gaskets
    Rich
    Rich------
    Do you want "correct" gaskets or the best gaskets? The two are not necessarily the same.
    • Ray K.
      • July 31, 1985
      • 375
      Rich,
      Original gaskets consisted of ( 2 ) steel shim gaskets per head. Do you intend to pursue the original makeup or are you considering a composition type gasket.
      Ray
      • Richard S.
        • April 1, 2003
        • 288
        Thanks Ray. I am waiting to see if Joe can provide me details on both types and then try to make up my mind.
        Rich
          • 43279
          Rich
          Rich------
          valve cover gaskets:
          most correct: Dr. Rebuild, genuine cork, "4 hole".
          most durable and best sealing: Fel-Pro Cork Lam #1604
          head gaskets:
          most correct: NOS GM #3830711 or Fel-Pro 7733SH1 steel shim type gaskets
          best: Fel-Pro Permatorque #1004
          (note: multi-layer steel (MLS) gaskets are actually the best but require block and head surface finish which are difficult to achieve)
          intake gaskets:
          most correct and best: NOS GM #3931600, GM #3734115 or Paragon Reproduction. These are embossed-type gaskets.
          timing cover:
          most correct: NOS GM #3799660
          best: GM #12369488 or Fel-Pro TCS51241
          oil pan:
          most correct: NOS GM #3818868 or GM #14079400
          best: Fel-Pro OS34509T (blue) or Mahle OS 32458 (black) these are one piece type gaskets
          thermostat gasket:
          most correct: NOS GM #3701777
          best: GM #10105135
          rear main seal:
          best: GM #10243247 or Fel-Pro #2912
          • Richard S.
            • April 1, 2003
            • 288
            Joe
            Thank you very much for all of that information. I do not know how you accumulated all of that data but I am glad that there is someone like yourself that maintains the detailed history of these old engines.
            Again, thank you
            Rich
            • Larry C.
              • April 1, 1980
              • 279
              Joe,
              Would your recommendations above equally apply to the 1962 340 engine? if not, where are the differences?
              Thanks, Larry
                • 43279
                Originally posted by Larry Chilton (3506)
                Joe,
                Thanks, Larry
                Larry------
                Everything I mentioned would remain the same for 1963.
                By the way, I should have mentioned something regarding the oil pan gasket. The recommendations I made only apply if the engine has an original oil pan or a pre-1976 GM replacement oil pan which is identical to the original. If the oil pan happens to be a post-1976 GM replacement oil pan (which is identical to the original except for the front gasket radius), then a different gasket or gasket set is required.
                • Richard S.
                  • April 1, 2003
                  • 288
                  Joe
                  My pan is original so I am good with the part numbers you provided.
                  Thanks again
                  Rich
                  • Larry M.
                    • January 1, 2002
                    • 538
                    for the 3818868 oil pan gasket do you know if it includes exhaust manifold to exhaust pipe gaskets and donuts...the reason I ask is that a guy on ebay is selling this and shows the exhaust parts as included. If the part number covers lower horsepower engines then his listing is bogus...if not I may buy one believing the exhaust parts are for 2 1/2 inch.
                      • 43279
                      Larry------
                      The GM #3818868 gasket set was cataloged for all 1957-63 small blocks, Corvette and otherwise. It did contain exhaust packings ("donuts") for 2" exhaust. If the gasket set was to be used for high/special hi-performance models, then GM instructed that GM #3767556 (2-1/2") packings be obtained and used. I do not think that the gasket set contained the triangular exhaust gasket.
                      • James W.
                        • December 1, 1990
                        • 2673
                        Joe,
                        Same question on engine gaskets but for a 1965, L79 327/350?
                        James
                          • 43279
                          Originally posted by James West (18379)
                          Joe,
                          James
                          James------
                          The same gasket set mentioned above, GM #3818868, was the gasket set originally cataloged for all 1965 Corvettes with small block. Of course, there were other sets supercessive to that which followed over the years. The first supercession was in March, 1966 to GM #3888084. The latter also was supplied with packings ("donuts") for 2" exhaust and required the separate purchase of the 2-1/2" packings for cars so-equipped.
