Valve Lash adjustment - NCRS Discussion Boards
  • Joseph F.
    • July 31, 1975
    • 36
    I will be adjusting valve lash on my 1961 270 hp engine. Any hints on how to get accurate adjustments with "poly lock" rocker arm nuts? Haven't done adjustments in a while and usually had difficulties maintaining correct clearance (.008" / .018") in the past.
    Thanks.
    Joe Feko NCRS 673
    • 43277
    Re: Valve Lash adjustment
    Thanks.
    Joe Feko NCRS 673
    Joe------
    If you have stock rocker arms, then I do not suggest using the "poly-lock" type nuts. I highly recommend stock-type, self-locking nuts.
      • 15706
      Agree with Joe... the OE rocker arm nuts are the way to go. I've never seen a breakaway torque spec for them, but I figure if less than 10 lb-ft they should be replaced.
      Also, a better valve adjustment spec for the Duntov cam is .010/.016". Do a Web search for the Hinckley Williams valve adjustment paper, which explains the reasons why and how to ensure that the lifter is on the base circle for each valve. Make sure you get the Sept, '08 revision. Earlier versions are also on the Web, but are obsolete.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11363
        The Sep 08 revision is here on our site.
        https://www.forums.ncrs.org/showthre...603#post807603
        File... Newer_Lash_Adjustment.pdf
        • Frank D.
          • December 27, 2007
          • 2703
          I had very little variance between annual valve lash settings on my 270hp 61 using original style rocker arms...
          • Joseph F.
            • July 31, 1975
            • 36
            Thanks for the reply. Was considering self-locking nuts as the car does not see much racing these days! I would think I should be able to get nuts from any parts store unless there is a special nut for the solid lifter engine.
            • Joseph F.
              • July 31, 1975
              • 36
              Thanks for the reply. Will get the paper.
              • Joseph F.
                • July 31, 1975
                • 36
                Thanks for the reply. Got the paper.
                • Joseph F.
                  • July 31, 1975
                  • 36
                  Thanks for the reply. Nice to hear from you again! Hood latches working just fine!!
                    • 43277
                    Joseph------
                    The self locking nuts with stock type rocker arms are better whether it's racing or street use. The only reason I can think of to use poly-lock type nuts is for use with roller trunnion rocker arms. Those cannot use self locking nuts. I wish they could.
                    Self locking nuts should be found at most auto parts stores or GM #12557390 (about $1.75/each, GM list)
                    Also, Sealed Power # MR 1751.
                    • Ray K.
                      • July 31, 1985
                      • 375
                      Joe,
                      I also agree with suggestions as mentioned to use GM type rocker arm nuts if you have stock rocker arms. Original #3744341 -- but discontinued for some time. Probably available from Sealed Power or Federal Mogul.
                      Duke's suggestion about valve lash settings also has merit. Personally, I like the .012 / 018 settings. This was the original specification for 1957-59 270HP and 283/290HP FI engines. In 1960 they revised the intake setting to .008 which remained in place until 1963. I owned a 270HP /283 for many years and tried many different combinations of valve lash adjustments, and finally settled on the .012 / .018 as my preferred setting. Remember, this is a " hot " setting.
                      Ray
                      • Jim L.
                        • September 30, 1979
                        • 1817
                        Joseph------
                        Joe,
                        There is one other reason: If you use ARP-brand screw-in rocker studs, they come with a warning against using self-locking nuts.
                        Jim
                          • 43277
                          Joe,
                          Jim
                          Jim------
                          Yes, they do have such a warning. However, as much as I like ARP fasteners, I use GM threaded studs for the rocker arms. However, I really think that the ARP studs could be used with self-locking nuts without any problems.
                            • 43277
                            Originally posted by Ray Kimminau (8917)
                            Joe,
                            Ray
                            Ray------
                            The GM #3744341 were replaced by the GM #12557390 I mentioned above which remain available.
                            • Jim L.
                              • 1817
                              Jim------
                              I take ARP's advice at face value on my racing engines and use polyloks. I think they are a PITA but I haven't had any failures.
                              I'm not familiar with the GM studs. I assume they have a hex at their base for wrenching. How does the radius from the hex to the shaft compare to that of the ARP studs?
                              Jim
