1962 front bumpers, license plate, bumperettes - NCRS Discussion Boards
  • Dino L.
    • February 1, 1996
    • 694
    Can you comment on the installation of my bumperette and license plate assembly. Does it look correct to you?
    Dino Lanno
  • Dino L.
    • February 1, 1996
    • 694
    Re: 1962 front bumpers, license plate, bumperettes
    After 44 views, I thought I should be more specific. In the picture you can see the top of the license plate at the same height of the crossbar.... I have searched the web and seen 62s like this but I have seen others who are lower. Not sure it gets lower unless it was shimmed.
    Dino
    Dino Lanno
    • Jerry M.
      • March 1, 1978
      • 147
      Dino
      FWIW here is a photo of my '62 from back in the 80's. Also look at Nolan's Rest Guide on pages 318 and 319. Based on these it looks like yours may be just a tad high unless it's the angle. No idea off hand how to lower or if it would be worth it.
      Your car's looking great by the way. Need to stop by and visit.
      Jerry M.
      • John F.
        • March 23, 2008
        • 2417
        Looks about right to me. My 62 Bowtie car was the same color as yours.
        • Frank D.
          • December 27, 2007
          • 2703
          Some of the cars you see with the lowered bumperettes and license plate holders have the wrong bumper braces...they are running earlier C1 braces designed to deal with the grill teeth. My 61 was wrong when purchased. I always say you should just be able to get your forefinger between the crossbar and the bumperette. BEFORE AND AFTER PICS attached. I too think the OP's are a bit high...
          • David R.
            • June 29, 2014
            • 183
            Here's my '62 for comparison:
            • Dino L.
              • February 1, 1996
              • 694
              Thanks Jerry and David. Jerry in your picture it appears your bumpers are adjusted to be raised to the top of the openings, where David and mine are centered. There are a few ways to change the height of license plate assembly. You can shim under the mounting bracket as it mounts to the front cross member. The other thing that effects it is the length of the cylindrical spacers for the two bumperette mounting bolts.
              Dino Lanno
              • Mike E.
                • February 28, 1975
                • 5141
                • Frank D.
                  • December 27, 2007
                  • 2703
                  Some of you may remember the old British MIRA analysis of a fresh off the line 1961 Corvette....this is the first picture from that document.. This is how adjusted mine....
                  • Edward B.
                    • January 1, 1988
                    • 537
                    Just to save everyone else from the trouble of fining the MIRA analysis:https://www.c1registry.com/downloads...e_Analysis.pdf
                    • Dino L.
                      • February 1, 1996
                      • 694
                      Made aadjustment to my bumperette assembly.
                      Dino Lanno
                      • Frank D.
                        • December 27, 2007
                        • 2703
                        I think you nailed it !
