C2 Clutch and Flywheel recommendations - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    This is for a C2 small block engine build.
    I need a clutch kit and flywheel. From researching here I think I will likely go with the following:
    LUK clutch kit 04-021 (strange price range NAPA $121.99 and Rockauto $70.99)
    LUK flywheel LFW131 (again strange price range NAPA $94.49 and Rockauto $52.79)
    Are the LUK parts OK, or are there other recommendations?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C2 Clutch and Flywheel recommendations
    Luk is good. But I’d prefer to resurface the original flywheel. Too many horror stories on bad vibrations after flywheel change.
    • Bob W.
      • December 1, 1977
      • 802
      Don, Take a look at Summit Racing they offer free shipping.
      clutch 89.99
      flywheel 67.99
      Bob
      • Carl S.
        • April 21, 2017
        • 18
        Don,
        You are correct. It is a big swing in cost between NAPA and Rock Auto but not surprising. I have found that in most cases Rock Auto can be anywhere from 25 to 75 percent cheaper than many of its competitors; especially with regard dealership prices. I have always had good luck with Rock Auto supplied parts. Wish you success with the build and let me know if there is anything I can do to help.
        C.J.
        • Donald H.
          • November 2, 2009
          • 2580
          Thanks Gene,
          Unfortunately I do not have an original flywheel. The engine came out of a passenger car with an automatic transmission.
          Don Harris
          • Wayne L.
            • September 30, 1981
            • 233
            Call Paragon-they have used parts for sale; or swap meets or salvage yards.
            • Gene M.
              • April 1, 1985
              • 4232
              Originally posted by Donald Harris (51003)
              Thanks Gene,
              Be sure to press in the correct pilot bushing.
