1965 Air Coupe at the Mecum Auction - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2669
    I noticed the air deflector on the top of radiator support on this '65 L79 equipped with A/C that will be auctioned at the Mecum Auction tomorrow. I have the exact same optioned '65 other than mine is Glenn Green. My '65 has been in the family since the mid 1970's and is mostly un-restored. I've never seen the air deflector on top of the radiator supported. I would assume this is an add-on device to aid in cooling. Anyone ever see this before?
    James
  • Gary J.
    • April 1, 1980
    • 1245
    • Leif A.
      • August 31, 1997
      • 3646
      Re: 1965 Air Coupe at the Mecum Auction
      Originally posted by Gary Jaynes (3503)
      That “air deflector” is on ‘66-67 A/C BB cars. Not sire about C3.
      Small block A/C cars, as well.
      Leif
      • Michael J.
        • January 27, 2009
        • 7156
        It's a rubber seal across the top of the radiator to ensure tight air flow through the radiator, not an air deflector.
        • Jim D.
          • 2885
          65 non-air big blocks had something similar.
          • Ray K.
            • April 30, 2005
            • 405
            Don't have this rubber seal on my late build (July '65) AC small block coupe either . . . . .
            Ray K
            Member #43777
            • Scott S.
              • March 1, 1979
              • 747
              Our 1967 SB has one.
              Scott
              • Harry S.
                • July 31, 2002
                • 5333
                I got one from Paragon and modifird it to fit my 63 A/C car to help with the cooling.
                • Tom D.
                  • September 30, 1981
                  • 2139
                  Upper Seal Not mentioned on page 202 of the TIM&JG. (6th Ed., Chassis Section, Technical Information Manual and Judging Guide).
                  https://MichiganNCRS.org
                  Michigan Chapter
                  Tom Dingman
                  • Wayne M.
                    • March 1, 1980
                    • 6414
                    Although it must have helped seal for airflow, its main purpose was to silence hood rapping/flutter against the 396 rad support.
                    • Jim D.
                      • 2885
                      Thanks for the info. Wayne. Mine was built 50 cars after the implementation of that update.
                      • Michael J.
                        • January 27, 2009
                        • 7156
                        Very interesting, I didn't know you could get A/C with the 396.
                        • Jim D.
                          • 2885
                          You couldn't.
                          • Michael J.
                            • January 27, 2009
                            • 7156
                            Ah, OK, so they had the A/C style rubber seal across the top of the radiator, but no A/C. Got it.
                            • Leif A.
                              • August 31, 1997
                              • 3646
                              Michael,
                              Different style completely. Look at the picture in post #5 of the 396 seal. Hope you and your family had a blessed holiday season. Happy New Year.
                              Leif
