'67 L71 Correct Engine images - NCRS Discussion Boards
  • Harvey W.
    • August 31, 1999
    • 37
    I am looking for some help. I have a '67 L71 built mid to late June '67. The car has never been restored, only maintained. After owning it for 20 years, while a fun driver, I am going back and trying to correct things that were done to it along the way. It has the wrong valve covers and the temperature sensor and wire seem to be located incorrectly. I would appreciate images of the engine of an L71 that has been judged as correct. Particularly looking for what correct valve covers look like, and the routing of the temp sensor wire and placement of the sensor itself. Thanks in advance.
    Harvey Wooding 32769
  • Danny P.
    • Today
    Re: '67 L71 Correct Engine images
    This is my L71 shows temp. wire run along intake toward firewall to harness
    • Harvey W.
      • August 31, 1999
      • 37
      Thanks Danny. This is what I thought it should look like but with the wrong valve covers mine was not routed correctly.
      • Danny P.
        • Today
        if you need any other photos let me know Harvey.
        • Gene M.
          • April 1, 1985
          • 4232
          Not correct paint margin on intake manifold. It was painted with a mask. And the exhaust manifolds would have orange overspray.
          The photo is too much out of focus to help with anything else.
          • Danny P.
            • Today
            Hi Gene , here a better picture of my L71 with overspray on exhaust I was just showing Harvery on the Temp. Switch wiring on the last photo
            • Harvey W.
              • August 31, 1999
              • 37
              Danny
              Sorry for the delay - household duties!
              If it is not too much trouble, I would appreciate two more photos - one of the temp sending wire as it attaches to the sensor and the actual location of the sensor. It appears to be inserted into the intake itself. My sensor has been relocated because I don't have the correct intakenor valve covers I believe. Would also like a view of the right hand valve cover. I have located a pair of used originals, but they are tough to find, not in great shape and expensive. As I said I am trying to make things right under the hood, but this is not a full restoration project. Just trying to make a really nice old car as right as I reasonably can. The next keeper can restore it.
              Harvey
              • Danny P.
                • Today
                Hi Harvey , photo of the right side valve cover and Temp. Switch and wire connector
                • Harvey W.
                  • August 31, 1999
                  • 37
                  Danny - These show me exactly what I needed to confirm. This was how I pictured it to be, but wanted to be sure before I proceed with my search for the correct pieces. Thanks so much.
                  • Ara G.
                    • January 31, 2008
                    • 1108
                    Keep in mind the original valve covers were spot welded and the weld marks are discernible from the top of the valve cover. While reproductions have done a decent job to replicate the look, the "step" on the outer circumference of the covers is different than that on an original valve cover. Also, the Tonawonda decal is applied to the valve cover PRIOR to it being painted so it should be in the paint, not on top of the paint. ARA
                    • Harvey W.
                      • August 31, 1999
                      • 37
                      Thanks Ara I was aware of the spot weld marks correctly being visible. I was not aware of the placement of the Tonawonda sticker prior to painting. I will keep those two points in mind as I search.
                      Harvey
