Attached is a photo of 5 different Original 4-speed reverse levers numbered 1-5.
Lever #1: GM # 3846891, 64-67 Corvette
Lever #2: GM # 3920731, 68 Corvette
Lever #3: "Modified GM # 3960379" (69-73 Corvette) made by Long Island Corvette #32-14, as an "early days reproduction" of the 64-67 Corvette reverse lever that I purchased in August 1983 for $10 before I knew any better. This "early days reproduction" looks more like the 68 Corvette reverse lever as all the 3 holes line up and the shape is similar.
Lever #4: Unknown, measures 2.09" long by 1.32" maximum width
Lever #5: Unknown, measures 2.81" long, 1.125" wide at slot, 0.74" wide at large hole, 0.95" wide at small hole.
According to the 1969 Corvette Assembly Manual (M20, A2) reverse lever 3946756 was replaced by reverse lever 3960379 as per the revision record dated 9/12/68. GM # 339744 is listed for 74-77 Corvettes w/H.P. The 378205 reverse lever (77-81 Corvette) is stamped "8205". GM # 378183 is listed as 1st design for 78-79 Corvettes.
Can anyone identify Levers #4 and #5?
Dave
Dave
