Installing C2 bumpers; spacers inside the front bumper ends - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    The center brace that comes out from the cross member connects to the front bumper end. It is secured with 2 bolts with a spacer inside the center brace channel. How do you get the spacer in there???--especially the most forward spacer. Also is it easiest to install the center brace to the bumper end first and then connect the whole system to the cross member? Just looking for ideas.
  • Frank D.
    • December 27, 2007
    • 2703
    Re: Installing C2 bumpers; spacers inside the front bumper ends
    I've done it both ways but if working alone I feel that having the center brace attached to the bumper and installing them as a unit is easiest...you can get the rear bolt on the brace started through the crossmember then lift the bumper itself up and get at least one bolt attached to the center brace at the front to get the installation started without damage... That's the method used in the attached pictures.
    The small metal cylinders that go in the crossmember brace can be a pain; especially if someone tightened the braces to the point the channel is deformed. I've had to remove the brace and open the channel up to accommodate the spacer and I have ground a spacer or two to get them installed. Basically try to hold the spacer in position as you start the bolt through..sometimes aligning the spacer with the brace holes with a beefy screwdriver through the holes first helps.
    • Paul S.
      • June 30, 1982
      • 354
      i agree with what frank said . if they are original bumpers and they are repro spacers , be ready to grind them shorter because they wont fit .
