Details on bolt for alternator bracket to wire harness (3952222) - NCRS Discussion Boards
  • Terry L.
    • August 13, 2007
    • 99
    Re: Details on bolt for alternator bracket to wire harness (3952222)
    I know this is an older thread, I have looked at 4 of these bolts recently ( 3952222 ). All the bolts have a distortion in the threat mid way down the bolt similar to a self taping screw, Maybe this portion of the thread is to help facilitate a better ground and the reason for the special bolt designation?
      • 43247
      Terry------
      That could very well be the case. I had not noted that on the specimen I had available. I'll have to check that when I get home from this trip.
      • Ray K.
        • April 30, 2005
        • 405
        #18
        • Terry L.
          • August 13, 2007
          • 99
          #19
          This is one of the bolts i had access to today. I will take a pick of another bolt tomorrow
          • Mark E.
            • April 1, 1993
            • 4600
            #20
            1970 AIM shows a "L. Washer" is used. I assume this is an abbreviation for lock washer but the diagram depicts an external star washer. Stars are typically used to help ensure good electrical contact, not as a lock washer. Would a bolt with distorted threads be used in addition to a star washer? The former to keep it tight, the latter for electrical contact?
            Order shown is: Alternator-->L. Washer-->Ground Wire-->Bracket-->Bolt. If there's a washer in Terry's photos, it's hidden behind the bracket.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Terry L.
              • August 13, 2007
              • 99
              #21
              Here is a picture of another (3952222) bolt. Same distortion in the thread.
              • Ray K.
                • April 30, 2005
                • 405
                #22
                Mark,
                My 1971 AIM (UPC: 12, Sheet: A7, Item #2) shows an external tooth lock washer, part number 138479. It's a #10 external tooth lock washer.
                My 1972 AIM (UPC: 12, Sheet: A8, Item #6) shows an external tooth lock washer, part number 138485. It's a 5/16" external tooth lock washer.
                I've owned my '71 LT1 since "day one." It has the external lock washer on it as drawn in the '71 AIM.
                Ray K (#43777)
                  • 43247
                  #23
                  My original owner 1969 has always had the external tooth star washer, too
