electrical short - NCRS Discussion Boards
electrical short
  • Phil A.
    • April 30, 1982
    • 121
    electrical short
    1971 LT-1 I rebuilt starter and bypassed the clutch safety switch. Turned on the ignition switch and when I turn it to start the interior lights go very dim indicating a bad short. I then ran a wire from the s terminal of the starter solenoid to a 12 volt source on the car with the ignition in the start position and got the same result. I had the starter checked on a machine and it was ok. Anyone have any ideas? Thanks in advance, Phil
  • Mark E.
    • April 1, 1993
    • 4613
    Re: electrical short
    Was it in the start position, or run position when you hot wired the solenoid?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Paul Y.
      • September 30, 1982
      • 570
      Phil, I trust the ground cable is clean and makes good contract on the starter bolt.
      It's a good life!
      • Richard G.
        • July 31, 1984
        • 1718
        Did the motor rotate when the starter was engaged?
        • Dan P.
          • December 1, 1990
          • 683
          Did you have the battery checked
