231 Delco Remy Coil - NCRS Discussion Boards
231 Delco Remy Coil
  • Mark S.
    • July 31, 1983
    • 660
    231 Delco Remy Coil
    I picked up several Corvette parts from a person that had a 66 big block TI. He said that he had problems with the ignition system; but found out it was distributor related. A 231 coil was in the parts that I received from him. Does someone have a picture of a repop 231 coil; or can tell me the difference between a repop and an original? I did see pictures of an original one that Dave Strickland was selling; and the one that I have looked very close to Dave's. Thanks! Mark
  • Dave S.
    • August 31, 1992
    • 2925
    Re: 231 Delco Remy Coil
    Mark,
    Identifyong an original Delco Coil vs. a repop. should be pretty straightforward. Repops I have seen have non magnetic studs and the DELCO REMY font is not very crisp on a repop. Just compare it to any original Delco Coil and you can easily tell the difference. Does your coil have a decal or remintants of one.?
    If it was in a box of old parts that's a good sign as the repros haven't been around that long.( 10 years or less). Hope that helps
    • Mark S.
      • July 31, 1983
      • 660
      These are pictures from my 231 coil. Does it look to be an original? Also, this is the first time for me to post pictures. I hope that they are okay. Mark
      • Dave S.
        • August 31, 1992
        • 2925
        Mark,
        Good photos and a good job posting them. The decal is a reproduction but I'd say the coil is a real Delco Coil. Are the posts magnetic.?
        i test them on a car. Run it to temperature, take it for a test drive and install the shielding. If the heat doesn't kill it then it's a good coil.
        • Mark S.
          • July 31, 1983
          • 660
          Dave: The posts are magnetic. Thank you very much for the help! Sincerely, Mark
          • Gene M.
            • April 1, 1985
            • 4232
            Mark,
            Hi Dave,
            Would you happen to know the ohm reading resistance of the 231?
            • Dave S.
              • August 31, 1992
              • 2925
              Originally posted by Gene Manno (8571)
              Hi Dave,
              Gene,
              I do not. All the various Delco coils that were made for TI and non TI cars must have meant something but I've never heard a good reason why that was done. I'm sure the reason exists but I've never heard it. From 64-71 when TI was offered I'll bet there were about 10 different coils installed in St. Louis but only one was serviced (#207). I have always thought that was strange.
              • Mike B.
                • July 31, 1994
                • 839
                Here's 2 shots of my buddy Mark Nagy's extra 231 coil. Nice original.
                Mike
                  • 15601
                  Gene,
                  I believe that the coils were shipped to St Louis with the mounting bracket. Thus the number on the PRODUCTION coil included the appropriate mounting bracket. The coil itself may, or may not, have been the same. I am sure that electrically the ones for TI were different than the ones for points ignition, but beyond that I am at a loss for an eplaination.
                  • Ken A.
                    • July 31, 1986
                    • 929
                    Why do you say the sticker is a repop?
                    • Dave S.
                      • August 31, 1992
                      • 2925
                      Ken,
                      Original stickers have a paper backing and the repro stickers do not. I don't see any thickness of paper backing in Mark's photo. Does that look like a sticker that is 52 years old.? Patina is part of determining age in my opinion.
                      • Mark S.
                        • July 31, 1983
                        • 660
                        I am guessing that the resistance for a TI coil should be close to 0.41 - 0.51 ohms; according to Dave Fieldler's information?
                        • Ken A.
                          • July 31, 1986
                          • 929
                          No, but neither does the coil. In my opinion it looks like a paperback from the picture.
