1967 Trip Odometer - NCRS Discussion Boards
1967 Trip Odometer
  • Donald O.
    • May 31, 1990
    • 1593
    1967 Trip Odometer
    There is a black foam light shield/gasket inside the cluster that surrounds the trip OD, I replaced it but I believe it had adhesive on it to keep it attached and in position. I guessing that it had a peel-n-stick when initially installed, the reprop isn't.
    Would contact cement be appropriate to use, or should I seek out some double sided cellophane type tape to use instead?
    The light at the end of the tunnel has been turned off.
  • Donald O.
    • May 31, 1990
    • 1593
    Re: 1967 Trip Odommeter
    Nobody knows the answer?
    • Harry S.
      • July 31, 2002
      • 5344
      Don, I've used the very thin two sided cellotape/cellophane tape that you mention. worked well.
      • Donald O.
        • May 31, 1990
        • 1593
        Thanks Harry
        Don
