67 BB Hood - NCRS Discussion Boards
67 BB Hood
  • Bjorn J.
    Infrequent User
    • February 13, 2017
    • 5
    67 BB Hood
    Can anyone help to tell or show pics of correct stinger hood on the underside
    some tell mine is but nut sure
  • Ray G.
    • May 31, 1986
    • 1189
    Re: 67 BB Hood
    Hope this original picture helps.
    I hope you dance
    • Douglas L.
      • August 31, 2003
      • 302
      Re: 67 BB Hood
      Bjorn,
      I see a different in the rivets. But, I cannot comment on what that means, if anything.
      • Thomas N.
        • July 31, 2002
        • 408
        Re: 67 BB Hood
        It is the second generation GM service replacement part. The rivets are different, and if you look at the fairing of the underside support and the hood panel, you see no excessive bonding adhesive. Typical factory production has the flat rivets (not rounded) and the fairing is done so that you can't see the space/gap where the underside framework meets the hood top panel.
        The third generation GM service replacement part is the one piece molded hood with all of the ribs on the underside and not a two piece construction.
        NCRS New England Chapter Chairman 2022, 2024
        N E Regional Chairman 2024
        1967 Corvette Convertible Under Restoration
        1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
        • Keith B.
          • September 15, 2014
          • 1604
          Re: 67 BB Hood
          I am sure the current repro hoods use the wrong rivets as well
          • Bjorn J.
            Infrequent User
            • February 13, 2017
            • 5
            Re: 67 BB Hood
            thanks for the info
            Very helpful, so that means there should not be a gap as on my hood , but flat and smooth
            • Thomas N.
              • July 31, 2002
              • 408
              Re: 67 BB Hood
              And Flat rivets, with no dome.
