Are these vacuum hose ends available? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1416
    Guys,
    I just ordered a replacement set of all the climate control vacuum hoses for my 69 non AC coupe. The kit came with individual hoses only, and did not come with any of the specific hose ends that are seen in the pics I've attached. Can I re-use the originals or do I just connect the replacement hoses directly on to the vacuum ports? Thanks for your assistance.
    Mike
    • 6958
    Re: Are these vacuum hose ends available?
    Mike you may be able to remove the hose from the connecter, they maybe glued, take a small pocket screwdriver and work around the perimeter of the hose connector. maker sure the dia. is the same. as a last resort you can also use a plastic vacuum connector.
