Which Engine Plant - NCRS Discussion Boards
Which Engine Plant
  • Dan A.
    • May 31, 1974
    • 1073
    Which Engine Plant
    Is it known for sure which engine plant this is? Or are these engines being off loaded at a car/truck assembly plant? If the latter is it known which engine plant these V8s are from?
    Same questions for the below photo.
  • Tom D.
    • September 30, 1981
    • 2147
    Re: Which Engine Plant
    Dan: Railroad Car says "New York Central". I'd vote for Tonawanda, NY. No distributors in the second photo...
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Gary C.
      Administrator
      • October 1, 1982
      • 17965
      Dan,
      Terrytown NY plant photos look similar to the engine one you posted.
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Guest
        agree with master chesnut
        • Tom B.
          • March 1, 1978
          • 726
          Just to make things more interesting I pulled up a map of the old New York Central System and it shows a route up through Flint.
          • Michael J.
            • January 27, 2009
            • 7175
            Gary is right, that top picture is labeled "Engines as received at Tarrytown Assembly Plant, 1959"
            • Mike E.
              • February 28, 1975
              • 5152
              http://www.camaros.org/assemblyprocess.shtml
              • Dan A.
                • May 31, 1974
                • 1073
                If we accept that this is the Tarrytown NY assembly plant, is it known which engine plant they acquired their V8 engines from?
                • Harry S.
                  • July 31, 2002
                  • 5346
                  My wife was the second shift Nurse at Tarrytown and she says it sure looks like Tarrytown to her.
                  • Michael J.
                    • January 27, 2009
                    • 7175
                    I would say it was most likely the Flint engine plant, since they built 45 million V8s.
                    • John D.
                      • June 30, 1991
                      • 875
                      Yes that's the GM plant in North Tarrytown, NY from Life magazine. I worked there as a Manufacturing Engineer in the Body Dept from 1985-1995.
                      • Michael J.
                        • January 27, 2009
                        • 7175
                        What cars were made there when you were there?
                        • Dan A.
                          • May 31, 1974
                          • 1073
                          I'm asking in an attempt to find the facts, not mere speculation based solely on quantity. Someone else might speculate that Tarrytown received their engines from Tonawanda because it's 250 to 300 miles closer depending on the shipping route. Little is learned by shooting from the hip.
                          • Michael J.
                            • January 27, 2009
                            • 7175
                            Jeeseee, sorry I am not an expert.
                            • Dan A.
                              • May 31, 1974
                              • 1073
                              I didn't think Tonawanda made any small blocks back in those days.
                              Sometimes it pays to do your home work. As I said shooting from the hip and not thinking as you say is not likely to yield the desired result.
