Original 1963 Grand Sport? - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    What type brakes were used on the Original 5 Grand Sports? Disc, metallic drum, etc?
    Thanks.
  • Michael J.
    • January 27, 2009
    • 7122
    Re: Original 1963 Grand Sport?
    I do not know for certain, but I would guess maybe the top racing brake at the time GM had, the J56 package that went into Z06s. However, I do see some mentions of Australian made Girling solid disc brakes being used, but don't know if that is the original brake package. Here is the reference to that:
    http://www.superchevy.com/features/1...-corvette-005/
    • Bruce B.
      • May 31, 1996
      • 2930
      Here is what I found: Girling solid disc brakes with solid rotors were used, from a article in Super Chevy Mag.
      Thanks Michael Johnson.
      • Jim L.
        • September 30, 1979
        • 1808
        Girling solid discs with 3 pot calipers were used initially but proved inadequate. Vented rotors, similar in concept to what were introduced for production Corvettes in '65 replaced the early solid discs. AFAIK, Girling 3 pot calipers compatible with the extra width of the vented rotors replaced the earlier Girling calipers.
        Jim
        • Steven B.
          • June 30, 1982
          • 3990
          Good morning Bruce! When the original white body 377 GS appeared at Notre Dame it had discs as described. Steve
          • Bruce B.
            • May 31, 1996
            • 2930
            Thanks Guys.
            A Merry Christmas to all of my Corvette Friends.
            Bruce B
            • Jim L.
              • 1808
              Here are photos of the front brakes, early and late. The rear rotors continued to be non-vented after the front rotors were changed.
                • 15672
                Thanks for the photos. It appears that there are two pistons on the outside and one on the inside of the first design, which is rather unusual.
                Given about 50/50 static weight distribution a 1g stop will yield about 65 percent front weight bias under maximum braking, so the front needs about double the brake torque and heat capacity as the rear, which means solid rear rotors are okay.
                The production disk brake system would have been fine with solid rear rotors (or narrow vented rotors) and two piston fixed calipers, but GM decided to use the same rotor and caliper castings on both ends as a cost saving move, but it cost some unsprung weight, and the piston diameters yield 65/35 brake torque distribution.
                • Jim L.
                  • 1808
                  Precisely. That's what I meant when I wrote they are 3 pot Girling.
                  • Jack M.
                    • March 1, 1991
                    • 1155
                    Here are several GS brake images during development (from the Revs Digital Library):
                    • Michael J.
                      • January 27, 2009
                      • 7122
                      Great pictures Jack, thanks! Now after looking at those puppies, I am wondering how they performed compared to the more conventional drum and metallic shoes J56 big brake package in the Z06s.
