1963 Rear Muffler Hangers... Current Thoughts - NCRS Discussion Boards
  • Chuck G.
    • May 31, 1982
    • 2034
    I've attached several photos from my AIM. They show braided straps, not the copper bands... used as the grounding method.
    Revision is dated 5-16-63. It says "View Added". That added view, compared to the AM only radio, is the center illustration showing the braided straps. It also mentions that "Item 8 & 9 Added". Items 8 and 9 are the braided strap...and a toothed lock washer used to retain it.
    The JG says that the 3" wide copper band is used throughout 1963.
    Would that be true for a late car? When did the transition occur?
  • Harry S.
    • July 31, 2002
    • 5295
    Re: 1963 Rear Muffler Hangers... Current Thoughts
    Chuck, best I can recall neither strap was installed in 63 regardless of what the AIM says, The hanger itself provided the ground.
    • Chuck G.
      • May 31, 1982
      • 2034
      Thank you, Harry, however the most recent 1963/64 JG states:
      "In 1963, the rear muffler hanger system consists of a roughly triangular metal plate bolted to the underside of the frame with two bolts, nuts, and split lock washers. Onto this metal plate is bolted an upper metal bracket, with a "conveyor belt" style flat rubber insulator riveted to it, and a thick sheet of copper that is bent outwardly in the center to cover the rear surface of the rubber insulator."
      "Two metal retainers also cover the rear surface of the copper sheet, one of which serves as the muffler bolt plate, the other which serves as the upper rivet plate...... etc. etc."
      • Harry S.
        • July 31, 2002
        • 5295
        Chuck, just took these. Both my 63's are the same.
        • Chuck G.
          • May 31, 1982
          • 2034
          So, you do have the copper strap on both of your cars...
          • Rich Y.
            Infrequent User
            • April 1, 2012
            • 24
            Here is a photo of my original, untouched muffler hanger.
            • Chuck G.
              • May 31, 1982
              • 2034
              Thank you.. To Harry and Richard... What are the VIN's of your cars....OR if you don't want to post them, in what month were they built?
              Early, Mid, Late in production?
              • Harry S.
                • July 31, 2002
                • 5295
                Chuck, April 20th and July 19th.
                • Dave S.
                  • August 31, 1992
                  • 2924
                  The hangers on my 63 match Harry's photos FWIW.
                  There should be a ground strap between the lower and upper pair of bolts ( inner bolts as I recall ) on U69 cars. Not sure about AM only cars.
                  • Rich Y.
                    Infrequent User
                    • April 1, 2012
                    • 24
                    My car was built in February 1963.
                    • Chuck G.
                      • May 31, 1982
                      • 2034
                      My 63 is a July 13 build... so it's "late"...
                      Dave, you're saying that you think there should be a braided strap in addition to the copper sheet?
                      • Harry S.
                        • July 31, 2002
                        • 5295
                        According to the AIM, yes a strap is installed. But, I've never seen one on a 63. I believe it started in 64.
                        • Alan D.
                          • January 1, 2005
                          • 2038
                          Here is what Noland has documented: The 64AIM does not show any ground strap in the subject area, so do not believe it was ever used in 1964. Sorry for poor scan.
                            • 6942
                            I think that there was a change at some point the AM radio's had a different ground strap mounting method for the antenna, AM/FM radio's mounted in front of the rear #4 body mount on side of frame. AM was behind mount on underside of frame. the muffler ground strap was also changed to a braided strap when the AM/FM became a option. But this was what the JM says??, around 15xxx
                            • Dave S.
                              • August 31, 1992
                              • 2924
                              Chuck,
                              based on the info I guess that is what I'm saying.
                              Seems like this is an area of great confusion. If the AIM calls for a separate braided ground strap then it would have been additional to the exhaust hanger that was installed on all cars wether it had a radio or not. I'm new to this 63 stuff but one can only apply logic when the information is not clear. I have an April 10 AM/FM car. I would agree that the addition of a braided ground strap is like a double ground and doesn't make much sense but the information I've read leads you in that direction. Are there any experienced chassis judges out there.?
