1967 Turn signal wiring harness routing - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1588
    What is the routing of the turn signal's harness to the main harness connector?
    Since I didn't find anything in the AIM or my copies of the Service Manual, the Fact Book by Dobbins or the book by Nolan Adams....
    Looking inn the AIM - on UPC 9, Sheet A4:
    Does it go between Item #10 and the main bracket?
    or
    Does it go between Item #10 and the column bracket that is welded to the column jacket?
  • Gerard F.
    • June 30, 2004
    • 3806
    Re: 1967 Turn signal wiring harness routing
    Donald,
    Take a look at the second similar thread below. There are some 4 or 5 pictures showing the routing. On a 67 the harness connector from the dash goes over the steering column, and clips on the steering wheel column in an opposite curvature to the steering wheel column.
    It is confusing and I scratched my head until I saw the photos.
    Jerry Fuccillo
    • Donald O.
      • May 31, 1990
      • 1588
      Thanks Jerry.
      I knew how and where the TS Connectors mounted to the bracket, but the pictures finally showed me how the ribbon cable is/was routed.
      Don
