1954 fouls plugs - NCRS Discussion Boards
1954 fouls plugs
  • Ronald R.
    • May 31, 1989
    • 671
    1954 fouls plugs
    If I leave the choke on just a second too long I have to replace plugs. Anyone have this problem/ Hotter plugs/ what is cure? thanks Ronnie
  • Jim L.
    • September 30, 1979
    • 1816
    Re: 1954 fouls plugs
    Well, one solution is don't leave the choke on as long. I know that sounds like a smart azz answer, but I'm serious.
    On my '54, I pull out the choke and crank the engine. At the instant it starts, I push the choke most of the way in. After only a few seconds of run time, I push the choke the remainder of the way in.
    With the ultra short distance between the carburetors and the intake port, you really don't need or want a lot of choking.
    Jim
    • Dick W.
      • 10483
      Don't know what heat range you are running but for older cars I always went at least one heat range hotter that what was called for.
      Dick Whittington
      • Tony R.
        • April 19, 2017
        • 201
        • Jeff B.
          • April 30, 1980
          • 169
          A hotter plug might help. For "around town" and/or city type driving, a one-heat-range hotter plug helps, or an extended tip plug.
          1967 Coupe 427-390 w/air
            • 15706
            It would help if you tell us what plugs the owner's manual/AMA specs recommend. I don't know much about the early six-cylinder cars, but recall that the OE AC plug recommendation is heat range 5 or 6, which are on the hot side.
            Also tell us the brand/number of the installed plugs. If they are not AC what AC plug do they cross to. Cross reference charts are available on the Web from most manufacturers.
            • Chuck G.
              • May 31, 1982
              • 2036
              IIRC, it's either AC 44-5 or 45-5. These are the smooth insulator plugs...that use the ribbed boot.
              I always had better luck with Autolites in my 54... Can't remember the #
              • Ronald R.
                • May 31, 1989
                • 671
                AC 44-5 is what i have been using
                • Chuck G.
                  • May 31, 1982
                  • 2036
                  I had great luck with Autolite 303's in my 54. Never had good luck with any AC plug..
                  • Ronald R.
                    • May 31, 1989
                    • 671
                    thanks will try them RDR
                    • Jim L.
                      • 1816
                      Not to hijack this thread (much) but what is a 44-5 plug and how is it different from a plain 44 plug?
                      Expiring minds want to know.....
