1969 L71/L89 OEM Fan? - NCRS Discussion Boards
  • Daniel S.
    • January 14, 2011
    • 309
    Hi All,
    Can the community photos and specs of an OEM assembly line with a '69 L71 with L89 heads? Dimensions? Stamps? Rivet type?
    Thank you,
    Dan
    • 43259
    Re: 1969 L71/L89 OEM Fan?
    Originally posted by Daniel Schutzbank (52694)
    Hi All,
    Thank you,
    Dan
    Dan------
    All 1968 and 1969 Corvettes except some 1969 with C-60 used fan GM #3888366. This is a 5 blade fan. It is identified by an "H" and a "66" stamped on the hub section. There is nothing stamped on the blades and no GM part number to be found anywhere. There are usually examples of this fan to be found on eBay. Very unlikely to find an NOS example since this fan was discontinued in 1970 and replaced by the 7 blade GM #3955182.
    • Ray K.
      • July 31, 1985
      • 375
      Dan
      In addition to the above information this fan blade is identified as being 17 & 1/2" in diameter. It was also used for 1966-67 Corvettes with a 427 engine.
      Ray
      • Daniel S.
        • January 14, 2011
        • 309
        Thank you gents... I appreciate the quick info and was able to find the right one.
        Dan
