Shocking - NCRS Discussion Boards
Shocking
+ More Options
Posts
  • Jack A.
    • March 1, 2001
    • 129
    Shocking
    I am researching some shocks I found. I think they are Corvette.
    They are Delco
    # 319650 date code 190 74
    #319761 " 305 79
    They are spiral and came off a 61 C1 but are not correct for that year. Any idea what they go to?
    Jack Alexander 35730
  • David B.
    • March 1, 1980
    • 689
    Re: Shocking
    Date codes should lead you to an answer. Manufactured 1974 190th day & 1979 305th day.
    A real quick look found 3197643 applicable to Chev & GMC Truck, source code also indicated to replace with 4964590
    • Dan P.
      • December 1, 1990
      • 683
      Re: Shocking
      If my memory is correct . Those are over the counter replacement for A c1.
      • Jack A.
        • March 1, 2001
        • 129
        Re: Shocking
        I think you are correct. My research seems to indicate that they switched to the non spirals in 59/60.
        I cant use then so I may try to sell. I have one complete set and another 4 fronts.
