c2 327 oil pan - NCRS Discussion Boards
c2 327 oil pan
  • Peter T.
    Infrequent User
    • February 21, 2012
    • 29
    c2 327 oil pan
    When removing the oil pan is there anything else involved other than removing the steering 'stabilizer' . The car is a '66, 327 base engine.
    Thanks in advance, Pete
  • Bill M.
    • 1328
    Re: c2 327 oil pan
    Its ben a while but I think getting the starter out of the way helps.
      • 6950
      Re: c2 327 oil pan
      Peter, If you unbolt the idler arm at the frame side ( 2 bolts) and lower that will let you remove the pan. also starter as said above.
      • Larry M.
        • January 1, 1992
        • 2701
        Re: c2 327 oil pan
        There is also a "preferred" location/rotation of the crankshaft that reduces interference. I cannot remember the details, but it should be in the archives.
        This will facilitate removal of the pan.
        Larry
