1970 mirror gasket - NCRS Discussion Boards
1970 mirror gasket
  • Rick N.
    • August 25, 2017
    • 141
    1970 mirror gasket
    Does anyone have a picture of an original outside mirror gasket?
    Also, Does it have a part number on it?
    Thanks, Rick
  • Leonard M.
    • September 7, 2009
    • 236
    Re: 1970 mirror gasket
    From a '72; should be the same as a '70. Shown with a reproduction.
      • 43247
      Leonard and Rick------
      The gasket marked 461133 is not a reproduction, per se. This was the GM replacement part number for the original GM #3914599 gasket. The GM #461133 gasket was also used in PRODUCTION for 1977-79 Corvettes with standard outside mirrors. These mirrors had the same base and used the same attachment bracket as PRODUCTION 1968-76 outside mirrors.
      If the 461133 gasket pictured actually is a reproduction, then it's either a non-licensed GM reproduction illegally including the GM part number or a licensed reproduction produced under the GM Restoration Parts program.
      • Leonard M.
        • September 7, 2009
        • 236
        Joe, That 461133 came from Paragon so it would be a licensed reproduction.
          • 43247
          Leonard------
          ...or, from an inventory of the GM part that they obtained prior to its discontinuation.
          The thing I can't figure out is why they would reproduce the 461133 when it's only actually correct for a few model years. It would have been better if they had reproduced the 3914599.
          • Rick N.
            • August 25, 2017
            • 141
            Leonard,
            Thanks for the pictures.
            They were a big help.
            Joe,
            Thanks for your input as well.
