'67 Soft Plug For Steering Box End - NCRS Discussion Boards
  • Leif A.
    • August 31, 1997
    • 3653
    As the title reads. The question, is there a secret to installing this plug? Before I attempt it, I just wanted to hear from those who have put one in. Thank you.
    Leif
  • Gary R.
    • April 1, 1989
    • 1806
    Re: '67 Soft Plug For Steering Box End
    Clean the bore good, place some ultra gray in the bore, lay in the plug, tap it evenly in place. I use a brass rod to tap it every 90*, once in place use the rod on the center and hit it a couple of times to spread it. You should be able to reuse the original plug, I almost always do- on 100's of them.
    • Leif A.
      • August 31, 1997
      • 3653
      Gary,
      Thank you for your response. I, unfortunately, was asking about the incorrect part. The plug that I need to know about is the one at the end of the steering linkage that's inserted to block off the extra hole when power steering is used from the factory.
      Leif
