1957 1/4 flat washers - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    T
    he AM shows 2 different part numbers for the flat washers for 1/4 bolts .120392 and 120385 I believe one is USS and the other is SAE. I had all my hardware plated and there are 2 different size washers .So could someone measure the OD of the 1/4" flat washers that mount the inner fenders to the cowl 120392 on a unrestored car .Thanks in advance
  • David B.
    • March 1, 1980
    • 690
    Re: 1957 1/4 flat washers
    120392 SAE 1/4 zinc .281 inside X .625 OD X .065 thick
    120385 3/16 zinc .250 inside X .562 OD X .049 thick
    • Dan P.
      • December 1, 1990
      • 683
      What makes this so confusing is in the AM
      120385 is shown as the flat washer for 3/16 recessed head bolts for the lower filler panel and also shown for the 1/4 bolts that hold the hood strikers on .
      120393 is shown convertible top cover bolts while 120380 is shown for the decklid bolts . They are the same washer. 120393 is shown for the horn bolts which are 5/16??
