66 Frame stencil resurrection - NCRS Discussion Boards
  • Dan M.
    • February 1, 2000
    • 104
    Finally have the frame stripped of suspension parts etc and before I send off to the chemical stripper or blaster I thought I would try to reveal the frame stencil if I could. I have only used a mild cleaner and nylon brush so far and it seems obvious to me that unless the surface rust magically "disappears" the likelihood of uncovering the stencil is unlikely.
    However I thought I might as well ask you all if anyone has tricks or methods to try before I try something stronger or give up the chase.
    The attached pic shows the section (passenger side just forward of the kickup correct?). I dont know if its my imagination but I think I can see the faint outline of some white lettering. Might be wishful thinking.
    Any advice appreciated, thanks.
    Dan
  • Mike B.
    • July 31, 1994
    • 843
    Re: 66 Frame stencil resurrection
    Hi Dan,
    This is a topic that I recently did research on. Luckily through NCRS Forum posts I'm pretty sure what my stencil should look like. My '66's original was illegible and I selected the wrong one and painted it on the frame. My body is still off the frame so it'll be easy enough to fix the error.
    Do a search of this post by Dan Termeer on frame stencil paint. Sorry, I don't know how to link to archive posts yet so I'll attach a shot of the thread by Dan. It was very helpful to me. Everyone had something good to add to the discussion, but check out posts by Gary Beaupre. He's compiled detailed frame stencil files. Maybe you can post your '66's build date then we can figure out the closest frame stencil that you should have. Once you know what it should look like you could then possibly read remnants of your original stencil? Betcha you could construct a stencil within a day or so from your original. Here's the thread shot. Good luck, Mike
    • Dan M.
      • February 1, 2000
      • 104
      Tks Mike. I'll check out these posts for some help. Although my frame is in excellent shape the surface rust and 50 years later the original stenciling is pooched. I like your idea. The final assembly date of my car appears to be April 21, 66.
      Tks
      Dan
      • Mike B.
        • July 31, 1994
        • 843
        Great Dan,
        Thanks to Gary I'm pretty sure of the stencil I'll have Quanta reproduce for my '66. I think I've nailed it down.
        On a separate note......I'll bet your shop smells great! That looks like real cedar board paneling. Hmmmmmm....what a great idea. Mike.
        • Dan M.
          • February 1, 2000
          • 104
          Ha. Its actually pine but it smells great.
          Heres a bigger shot. Should have built a bedroom in here.
          • Don H.
            Moderator
            • June 16, 2009
            • 2269
            Mike,
            to place a link to another thread into your post, just left click, or two-finger tap your scroll pad with your cursor over the https address of the thread in your browser bar. This will highlight the address (it will turn blue) and give you a menu box. Hit the Copy command. Then go to your post in the new thread and left click or two-finger tap to bring up the menu box again. Hit the Paste command. The link will be in your post.
            https://www.forums.ncrs.org/showthre...=stencil+frame
            • Mike B.
              • July 31, 1994
              • 843
              Thanks Don,
              I'll practice this in one of my threads. Gotta make a copy of these instructions. Thanks!
              Mike
              • Mike B.
                • July 31, 1994
                • 843
                Dan,
                Pine sounds great too! But the wife and I have always enjoyed the aroma of cedar. We're planning on an addition to the shop with a high rafter ceiling for a lift. An end wall in paneling would be great! Thanks for the great idea. It'll keep insects down too.
                Here's a shot of where the sisters live now. The yellow '65 and blue '66. Mike
                • Mike B.
                  • July 31, 1994
                  • 843
                  Sorry Dan,
                  Drifted away from your subject. From researching different threads and reading what Gary has posted, there's another subject of crayon dates. Make sure you investigate this. When I bought my '66 frame stencil from Quanta way back when they only had one variety. They also sold crayon kits.
                  Well, come find out my stencil was wrong and I shouldn't have drawn a crayon date on my frame as the date is included in the correct stencil. My build date is December 1st, '65 so I've selected November 29th as the date in my proposed stencil. Now Quanta makes customized stencils to order. I'm still doing final comparisons to VINs close to mine when I find them.
                  Mike
                  • Dan M.
                    • February 1, 2000
                    • 104
                    Good to know. Im a long way from putting this one back together so I'll make sure I do the research.
                    Tks
                    Dan
                    • Wayne G.
                      • April 30, 1984
                      • 143
                      • Dan M.
                        • February 1, 2000
                        • 104
                        Great idea. Shouldn't have thrown it out back in the 70's!
                        • Mike B.
                          • July 31, 1994
                          • 843
                          I know I've got one somewhere wrapped up in an old Jimi Hendrix poster. I've seen them for sale in Spencer's Gifts a while back. Don't know if they're still in business?
                          Dan, I replied to your PM.
                          Mike
                          • Stephen L.
                            • May 31, 1984
                            • 3162
                            • Dan M.
                              • February 1, 2000
                              • 104
                              I would have never thought the stencil would be visible after a chemical dip. That's impressive.
                              I was considering media blasting the frame but perhaps I'll do the same as you. I assume you had no issue with chemical leaking out long after?
