1969 Corvette Big Block Radiator - NCRS Discussion Boards
  • Daniel S.
    • January 14, 2011
    • 309
    Hi Gents, what does not radiator decode as? Supposed to be a big block/manual trans, late 68 unit for an early 69.
    Does this appear to be correct?
    Dan
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 1969 Corvette Big Block Radiator
    What is the number after the L? That would be your year.
    • Daniel S.
      • January 14, 2011
      • 309
      3... I assume 1973?
      That's a shame
      Dan
      • Russ S.
        • April 30, 1982
        • 2163
        That's what I thought it looked like.
          • 43288
          Dan
          Dan------
          This is not a 1969-72 big block radiator, either by code or configuration. For one thing, 1969-72 big block radiators had no provisions for a filler cap.
          My best guess is that this is a later C3 small block radiator.
          • Daniel S.
            • January 14, 2011
            • 309
            You're 100% correct Joe. I did not even realize that until last night when I looked at the pics again.
            Thanks for your confirmation too
            Dan
              • 43288
              Dan
              Dan------
              "ML" coded radiators of this general configuration were used for many 1976-79 Corvettes
              • Russ S.
                • April 30, 1982
                • 2163
                Joe, Why then would a ML tag have a date of 3 if they weren't used in or by 1973?
                Dan------
                  • 43288
                  Russ-----
                  It could have been a SERVICE radiator manufactured in 1983. It's also possible that the original 1973-75 radiator, GM #3027967, carried the "ML" code. I doubt the latter but I don't have any info on that radiator.
                  • Tom R.
                    • June 30, 1993
                    • 4105
                    In my survey of buildsheets, the ML code is prominent in 1978 and called out when heavy-duty requirements were needed like C60, M38 and ZN1 (trailer package).
                    I don't see a use of ML prior to 1978 but do see MK and MI codes on 76-77 Corvette buildsheets. I wouldn't be surprised to see ML used during these years for heavy-duty requirements.
                    Tom Russo
                    78 SA NCRS 5 Star Bowtie
                    78 Pace Car L82 M21
                    00 MY/TR/Conv
