5450649 Wheel Cylinder for a 63 right rear - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5334
    I tried to replace all my bleeders front and rear. Three were fine but one of the rear wheel cylinders would not accept the bleeder. The bleeder in the wheel cylinder was small in diameter. I went to my box of cores and they were fine.
    I rebuilt one of my cores and installed it this afternoon. Time to bleed the brakes.
    Anyone know why that wheel cylinder would have two different bleeder sizes?
    • 6950
    Re: 5450649 Wheel Cylinder for a 63 right rear
    Harry, I have seen this with aftermarket wheel cylinders very common,If it was NOS one it may have been a later service replacement ?
    • Harry S.
      • July 31, 2002
      • 5334
      ED, it was NOS.
      • Tim T.
        • December 9, 2009
        • 141
        Several years ago I purchased a set of supposedly original wheel cylinders and MC off Dec - Jan 1963. Correct part numbers.
        When I went to rebuild them, I noticed the bleeders were small in diameter. Further investigation revealed they were metric threads!
        All other threads were SAE. Was told by a retired Delco Moraine engineer, that worked in the brake division at that time, that this was not possible.
        But I have proof. Please check yours, are they metric thread?
        • Harry S.
          • July 31, 2002
          • 5334
          I'll take a measurement later today.
          Some pictures to view.
          The bleeder on the left is what was installed.
          • Tim T.
            • December 9, 2009
            • 141
            Harry,
            Looks identical to all 4 of mine. Are all the threads SAE except the bleeder and it is metric ? Have been told it is not possible, but the metric
            bleeder screw is a smaller dia. than the "correct" SAE bleeder for that wheel cylinder !
            Tim
            • Alan D.
              • January 1, 2005
              • 2050
              Harry, the original one on my Mar64 has a minor difference as picture shows.
              Perhaps that may help tie down what's going on (do have same small bleeder)
                • 6950
                Harry it appears that there is a date in the first picture upper right corner, looks like (89)???
                • Harry S.
                  • July 31, 2002
                  • 5334
                  The bleeder is 8mm or M8x1.0, or
                  The bleeder is 5/16 or 5/16x24
                  8mm = .314961 incles
                  5/16 = .3125 inches
                  5/16 = 7.9375 mm
                  With the above I can't draw a conclusion as it's too close to call. It could be metric or standard?
                  Thoughts?
                  • Pat H.
                    • December 1, 1996
                    • 420
                    Harry, I have 4 of the 649's and they all have SAE 5/16 threads. 2 of them have been sleeved. Maybe someone cross thread one of them.
