67' body back on chassis without doors..is extra support necessary - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    I'm putting my 67' body back on the chassis. The body is painted and only has the windshield on it; no doors and the interior is still bare. Is it necessary to reinforce the door area with a bar or cable wire or is the Bird cage enough support were the body will not flex??
  • Dave K.
    • January 24, 2013
    • 278
    Re: 67' body back on chassis without doors..is extra support necessary
    I forget to mention it a convertible
    • Tom D.
      • September 30, 1981
      • 2150
      I say it is a requirement for a convertible. (Just had this discussion today at my local painter's shop!)
      Bolt the upper door hinge to a square tube (or a sturdy wooden stick). Make an L-shaped connection to the mounting plate for the door latch in the rear of the door opening. Make it tight.
      I have not done it with a cable, but it seems that would allow the "folding up" of your conv. body, such as in transit.
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
      • Jim D.
        • 2885
        Not needed on a coupe but definitely needed on a convertible. A simple brace between the top hinge and the door latch is all that's needed. Here's the brace on my current project.
        • Tom K.
          • February 26, 2008
          • 167
          • Patrick B.
            • August 31, 1985
            • 2017
            It should be fine with the doors latched. The braces are just substitutes for doors.
