74 BB - Lower Control Arm Shafts - NCRS Discussion Boards
  • Victor S.
    • August 24, 2017
    • 89
    Godd Day All!
    I'm rebuilding my front suspension using all GM NOS ball joints, tie rod ends, bushings etc. - just one question...
    My lower control arms on the 454 were natural on one side and painted black on the other side - looks like if incorrectly painted it was done long ago. I know the Judging manual says the arms are semi-gloss black but is the shaft natural are painted?? - looks like factory semi-gloss spray on one side and natural finish (no paint) on the other side but wanted to be sure if I need to remove it or not.
    Vic
    • 43258
    Re: 74 BB - Lower Control Arm Shafts
    Originally posted by Victor Scherer (63906)
    Godd Day All!
    Vic
    Vic------
    It's very possible that it originally came exactly as you found it. Various side-to-side differences for front control arms have been noted.
    The only other possibility that I see is that the side with the bare steel shaft had the shaft replaced at some point. SERVICE shafts from GM were always natural steel. I kind of doubt this, though, unless the car suffered collision damage at some point.
      • 11678
      As Joe mentions this is not unexpected.
      You will likely find that the one with the black shaft may also have the hardware on the ends (bolt/lock washer/large washer) painted black too.
      • Victor S.
        • August 24, 2017
        • 89
        Thanks guys - much appreciated!!
        • James G.
          • August 22, 2018
          • 805
          On Corvettes were the shafts attached to the Control ARMS prior to the ARMS being PAINTED?
          I ask because many other Chevrolet Vehicles have their cross shafts, bushings, Washers and bolts painted as part of the control arm assembly* -*which encompasses the Control Arms as well as the cross shaft bushings, bolts and washers.
          James A Groome
          1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
          1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
          My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
          Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
            • 43258
            James-----
            For Corvettes, some were, some were not.
              • 11678
              James-----
              And, it's not clear if they were painted once (same point on control arms as well as shafts) or twice (control arms painted, then shafts and hardware painted later).
              It appears - to me - that when I see paint on the shafts and hardware it's not as glossy or thick as the usual paint on the control arms. Other opinions may differ.
              PH
