53-55 radio - NCRS Discussion Boards
53-55 radio
  • John S.
    • July 29, 2009
    • 640
    53-55 radio
    Radio started to blow fuses. The last time the radio worked it melted the transformer on the speaker power pack. Any ideas on why this happened? Since then I removed the speaker assembly and tried the radio buttons. Buttons do not move station indicator bar. Does the speaker power pack need to be connected to the radio to have the buttons work?
  • Gary H.
    • June 30, 1980
    • 155
    Re: 53-55 radio
    Google : Charles Siegfried and see if he can help you out.....
    • John S.
      • July 29, 2009
      • 640
      Re: 53-55 radio
      Thanks, I have already talked to him.
      • Troy P.
        • January 31, 1989
        • 1279
        Re: 53-55 radio
        I'm guessing a bit here...I think it does not need to be, John.
        The power line goes to the powerpack which then feeds the tuner/receiver. So the signal seeking function, which is electric, will not work without the powerpack. But I think the tuner should move when buttons are pushed as that is a manual rather than electric station selection function.
        What happens when you try to tune by just turning the stations tuning knob?
