What kind of 4spd does my car have? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1424
    Guys,
    What kind of 4spd would my 69 350/350 non-AC car typically have? Need to order something for the
    tranny but not sure what kind it is. I have confirmed it is original.
    Mike
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: What kind of 4spd does my car have?
    It would be a Muncie. GM did borrow some Saganaw transmissions one year but 10 to1 it's a Muncie. If it involves a cluster or input shaft, there were 2 ratios. If it's stock the rear end ratio would be a clue.
    Dom
    • Gene M.
      • April 1, 1985
      • 4233
      How did you confirm the transmission is original if you don’t know what kid of tranny it is?
      S/b a Muncie.
      • Frank D.
        • December 27, 2007
        • 2703
        Originally posted by Michael Leonard (46610)
        Guys,
        Mike
        You should prob confirm what you have...
        • Michael L.
          • December 15, 2006
          • 1424
          • Ray K.
            • July 31, 1985
            • 376
            Michael,
            This would definitely be a Muncie 4 speed trans. It could be either a M-20 wide ratio ( 2.52 / 1 ) or an M-21 close ratio ( 2.20 / 1 ) transmission.
            The rear axle ratio is what determined the transmission selection. Axle ratio 3.36 and 3.55 used the M-20, while ratio 3.70 and 4.11 used the M-21. It is not likely that it would be a M-22 H.D. close ratio trans. Depending on what you need to order none of the above might not be relevant.
            Ray
            • Michael L.
              • December 15, 2006
              • 1424
                • 43290
                Thanks Ray. I need a side cover gasket so prob doesn’t matter. The car has 3.55 gears so prob an M20. Thanks again.
                Mike
                Mike-----
                The only component differences between 1966-74 M-20 and M-21 are the input gear and the cluster gear. All other component parts are the same for either.
                  • 43290
                  Dom
                  Dom------
                  No Saginaw 4 speed transmissions ever used for a Corvette. However, 1978-E79 with L-48 did use a transmission which was formerly known as a Saginaw. By that time, manufacture of this transmission had been transferred to the Muncie, IN transmission plant so it was referred to by GM as a Muncie.
                  • Domenic T.
                    • January 29, 2010
                    • 2452
                    Someone told me that the Munci plant had a fire and GM borrowed the Saganaw. Now I did take a 4 speed job on a 68 Camaro and it had a Saganaw in it. BUT who knows what happened with that Camero? Might have been a automatic once.
                    Dom
                    • Edward B.
                      • March 29, 2013
                      • 691
                      Dom, the 68 Camaro with the two 6 cylinder engines, the LF7 (327/210) and the L30 (327/275) engines all came with the Saginaw M20 transmission if ordered with the optional 4 speed, so it may have been original to the car.
                      Ed
                      • Ray K.
                        • July 31, 1985
                        • 376
                        The Saginaw 4 speeds were installed in Camaros, Chevelles, and Novas equipped with 6 cylinder or base 283 / 327 engines.
                        Ray
