C1 Hard Top Restoration Advice - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 941
    Has anybody restored their top and wish they would have outsourced this job ?
    Trying to decide if this is a job I want to do. I have lots of other things to work on but need some help deciding if I should farm this one out.
  • Joe M.
    • April 30, 1990
    • 1338
    Re: C1 Hard Top Restoration Advice
    I restored the hard top on my 1960 and would never do it again. If you have the money, farm it out and work on something or somethings else.
    • Frank D.
      • December 27, 2007
      • 2703
      A member on the Corvette forum said the same thing...
      Glassworks or Auto Entec will do it. Not cheap and a long turn around time though...
      Glassworks has several videos on the process:
      • Richard D.
        Infrequent User
        • September 30, 2005
        • 11
        I used Ron Lefler, he is in Calif., NCRS member.
        • Jim D.
          • 2885
          I restored the hardtop for my 1960 many years ago. Today, I just finished restoring the hardtop for my 65. Neither one was too difficult, just time consuming. I certainly wouldn't consider paying someone else to do something I can do myself.
          • Rick G.
            • March 1, 1983
            • 274
            Mark,
            Talk to Don in Livermore. He did the restoration on both hardtops for his 59 & 65.
            Rick
            • Keith R.
              • August 31, 2001
              • 660
              A local member of our Chapter who is in the Corvette restoration business with 30+ years of experience restored one for another Chapter member and he said that he would never do it again. I had mine done by Glassworks and they did a beautiful job. Send it off now as it is a two year project for them.
              Keith MacRae
              NCRS #36692
              New Mexico Chapter
              1960 290HP FI
              2013 427 Convertible
              Shade tree mechanic and
              B-52 pilot extraordinaire
              • Mike M.
                • May 31, 1974
                • 8400
                i've restored a 61 hardtop, tore it completely apart, got needed parts from glassworks, and put it all back together. no problems. took a weekend from start to finish. mike
                • Ed H.
                  • November 1, 1999
                  • 626
                  Mark, depending where you have your car, on the west coast I had Jeff Reade, American Motoring Memories Culver City Ca., rebuild my 57 top with Glassworks date coded side and rear Plexiglas windows. It took about two months, great job.
                  • Mark P.
                    • May 13, 2008
                    • 941
                    Thanks Mike. This is encouraging.
                    • Jim D.
                      • 2885
                      Mark, disregard the posts by those that have never done one and go with us that have. It's no big deal to do it yourself.
                      • Mark P.
                        • May 13, 2008
                        • 941
                        I disassembled the top this weekend and now have the fiberglass skin I can drop off at my painters so he can paint it when he paints the car.
                        It was more straightforward than I thought. It took 2 hours and everything came off OK. Will probably send the stainless out to be restored since I don't have a lot of time these days. An article on Corvette Forum helped a lot. Just Google "Brain Dump on restoring my 1958 hardtop" if interested. I used a flat chisel to pop off the 2 rivets on each side on the vertical supports and drilled out the rivets along the rear top section with a 1/4" drill. All other fasteners were slot or phillips screws. My top had been "restored" before so I had lots of silicone and adhesive holding parts. together which was a pain at times. A Hyde 5 in 1 painters tool with a stiff putty knife worked well to remove the trim, especially the 2 pieces that cover the top cross bow.
