Eaton Fan Clutch - NCRS Discussion Boards
Eaton Fan Clutch
  • Donald O.
    • May 31, 1990
    • 1593
    Eaton Fan Clutch
    I removed this fan clutch in June 2000 from my 1967 convert, 327/350hp no PB, no A/C, no PS.
    I added some notes in red to be able to read what was die stamped on it.
    What exactly is this and what is the date of it? I couldn't find any ink stamp or die stamping for a date.
    Don
    • 43289
    Re: Eaton Fan Clutch
    Don
    Don------
    This is a GM #3916141. It is definitely not original to the car and is a later replacement. The configuration of the silicone fluid reservoirs as well as other features differ from the original clutch.
    I don't know what the date code, assuming that's what it is, decodes to. However, as far as you're concerned it's a moot point since, as I say, this clutch cannot be original to the car.
